gearbox removal
d/c batt Neg.
support engine with a 2x4 across wings and a bit of rope in gearbox end lifting eye.
remove passenger wheel and unbolt hub carrier from ball joint, strut etc, pop inner CV out.
remove gearbox cradle.
remove starter, earth and bellhousing bolts.
jimmy bellhousing off block and lever it towards passenger side of vehicle.
drivers inner cv should pop out and the box is free.
car will have to be quite high in t'air tho.
jamie @ Jamsport did mine, real cheap aswell, top job, and he made it look easy!
arb off, cradle, starter, bellhousing bolts, abs (if you have it) driveshafts (be ready to collect oil)
if it ya 1st time have a day spare, just in case...
when i did them on my rs's they were pretty straightforeward, but the abs can be tricky...
get jamsport to do it!!!
Originally Posted by Tony Turbo
I think some of you take me too seriously. Just so you know...
... Was a joke
Take it out with the engine
... Was a joke
Its a bastard first time round , jacks supporting things here and there its a fooker i hate it
Then the abs belts
but im no mechanic by any means and you may find it a doddle , took us all in i think 5 hours in-out
Then the abs belts
Then the abs belts
Then the abs belts
got mike the fitter in work to agree to do it with me next weekend got all facilities and ramp in our place
as for removing the engine and box together
i only considered it as i need to remove the turbo and manifold and inlet manifold anyway for other reasons.so i will do it all in one hit
i only considered it as i need to remove the turbo and manifold and inlet manifold anyway for other reasons.so i will do it all in one hit Thread
Fudgey
Sep 17, 2015 01:06 PM
Si B
Sep 12, 2015 06:49 AM
grishenko45
Sep 9, 2015 12:58 PM
