Vibrations either CV/diff/gearbox :(
Old Jul 20, 2004 | 10:29 AM
Paul Eggleton's Avatar
Paul Eggleton
Default Vibrations either CV/diff/gearbox :(
Typically after spending tons of money and having the car handle and brake like a dream, its developed a horrible vibration/grinding noise coming from the front right. I have checked all the clearances on the floating discs and they are spot on.
It also only happens when turning left. I pulled back the outer cv boot last night and it looked to be in one piece if a bit dry. I have also noticed that i can feel a vibration after I come to a stop!, around my left foot area as if it is coming from the front diff/prop area. Obviously nothing is rotating so what might it be? Although I can't recall if I had the clutch dipped or not so it could be a gearbox problem although this shouldn't be affected by turning either way. All gears work fine.
Its booked in at SCC thursday anyway, but has anyone had any similar problems with shafts/cv joint etc As soon as i take the car from a straight line and turn right it goes away
Ta
Old Jul 20, 2004 | 10:35 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Exhaust needs repositioning. Brom had to do this for me as well. Five minute job - he knows what to do .
Old Jul 20, 2004 | 10:42 AM
Paul Eggleton
Hopefully, thats all it is cheers Mike
Old Jul 20, 2004 | 11:25 AM
Disabled Account's Avatar
Disabled Account
Yes, as Mike says............I had the same problem for a while.........but TBH it is more like a 15/20 min job as you have to remove the heat shield, loosen the 3 exhaust to turbo flange nuts and than tighten them in the correct sequence so as to "pull" the exhaust down pipe into the correct position.
Old Jul 20, 2004 | 11:26 AM
Mike Rainbird
Caraholic
Doug,
You haven't seen Brom work . Might take YOU 15-20 mins .
Old Jul 20, 2004 | 11:55 AM
kjc300's Avatar
kjc300
Happens to me all the bloody time!!!
Old Jul 20, 2004 | 01:23 PM
CozzyBrom's Avatar
CozzyBrom
no mike its not the exhaust i already done that
sounds like a cv joint mate
Old Jul 20, 2004 | 01:28 PM
Cosworth4388's Avatar
Cosworth4388
happens to me to
it is a ten min job!!
You will find that the exhaust is touching the bulkhead probably..
Old Jul 20, 2004 | 02:10 PM
Paul Eggleton
Old Jul 20, 2004 | 02:15 PM
DOO's Avatar
DOO
same prob exhaust but i changed the CV joint 1st
Old Jul 20, 2004 | 06:57 PM
Paul Eggleton
Just been under the car again and removed the sump/engine cover. Exhaust its mighty close to the chassis rail. I wouldn't be able to get a fag paper through there. Hopefully SCC will confirm this when they give it the once over Everything else feels and looks nice and tight with no problems.
Old Jul 20, 2004 | 07:27 PM
richm's Avatar
richm
Paul, although it doesn't sound like it's the cause of your issue - whilst you are under there, check the front proshaft front joint for wear, it can cause strange vibrations and knock on the exhaust downpipe - but often gives no warning before it comes apart causing huge mayhem..
Old Jul 20, 2004 | 08:21 PM
Paul Eggleton
I did have a look at this, looked OK from just a quick once over, should these be regreased in any special way?. THe prop is way clear of the exhaust though.
Thanks
Old Jul 20, 2004 | 08:29 PM
richm's Avatar
richm
they are effectively 'maintenance free' Paul (no greasing mechanism), but due to the proximity of the exhaust end up drying out the grease, with the subsequent wear etc.
You can replace the UJ if worn, and there is the possibility of getting one with a grease nipple fitted.
As long as you've checked and it's OK then that's fine - it makes an unbelieveable mess if it comes apart at speed!
Old Jul 20, 2004 | 08:38 PM
kjc300's Avatar
kjc300
Yes I know!!!
Old Jul 20, 2004 | 08:42 PM
richm's Avatar
richm
ah Kev - I had those pics in mind, just couldn't recall who it had happened to!!
Old Jul 20, 2004 | 08:58 PM
kjc300's Avatar
kjc300
150mph+ In belgium!!
Old Jul 21, 2004 | 06:25 AM
Paul Eggleton
You know how to fuck up a car then Kev Hopefully nothing similar will happen to me in Germany
Old Jul 21, 2004 | 06:56 PM
Paul Eggleton
ALl sorted now, the exhaust was rubbing on the side of the chassis rail. SCC kindly readjusted it all for me while I waited. Many thanks guys
Old Jul 21, 2004 | 07:03 PM
900ss's Avatar
900ss
RWD Racer
Paul
When you going to bring your car around
Old Jul 21, 2004 | 08:31 PM
Rob M666SCC's Avatar
Rob M666SCC
Pleasure
Old Jul 21, 2004 | 08:32 PM
Mike Rainbird
Caraholic
Told you so!
Brom , now apologise - you can touch me later if you're a good boy .
Old Jul 21, 2004 | 08:43 PM
Paul Eggleton
Told you so!
And I'm glad you are right, otherwise it could have been expensive!
Old Jul 22, 2004 | 09:16 AM
Sean Bicknell's Avatar
Sean Bicknell
Glad its sorted matey!!
Old Jul 22, 2004 | 09:33 AM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Nice one
pabloXR
Sep 21, 2015 12:42 PM
Fudgey
Sep 17, 2015 01:06 PM
talon1
Sep 15, 2015 10:27 AM
gingeRS
Sep 4, 2015 06:29 PM
jason_nike
Aug 31, 2015 10:15 PM
