Lag
Old Dec 20, 2005 | 12:51 PM
Ryan's Avatar
Ryan
Default Lag
How can you work out if a turbo is going to be laggy on a cossy?
can it be purely worked out from some specs and a comp map?
Old Dec 20, 2005 | 01:14 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
You can get a rough idea from the flow etc, but you can't really tell the response etc, until you get it on the dyno. This is why turbos are developed on engine dynos, that way you can experiment with all the variables .
Old Dec 20, 2005 | 01:32 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Can usually tell pretty well by engine and turbo spec, especially if can cross reference with other engines with the turbo (even if totally different types).
Got something in mind Ryan, if so post up, should be able to give you a fair idea.
Old Dec 20, 2005 | 01:34 PM
Ryan's Avatar
Ryan
my t61r
P trim 84 exhaust.
will get other spec's off the turbnetics site.
engine is your billet crank, billet rods, cosworth racing low comp.
cams would be suited to turbo, just getting CR, and port sizes
Old Dec 20, 2005 | 01:40 PM
Stu @ M Developments's Avatar
PassionFords Creator
Get a compressor and turbine map for it as a bare starter, then dig out a YB powergraph from a motor similar spec to the intended to get approx airflow figures....
How do you know that if you dont know if the turbo suits the engine?
Old Dec 20, 2005 | 02:00 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
cams suited to the turbo?! without knowing what the cams are i wont know if the turbo suits it, lol.
and depends what "suits" means, cams are all swings and roundabouts, higher boost threshold and more peak, or less peak and lower boost threshold.
without knowing cam n head specs, its hard to know, cams make a HUGE difference, esp when going big.
2litre?
T61R is similar in characteristics to GT35R TBH.
Old Dec 20, 2005 | 02:13 PM
Ryan's Avatar
Ryan
yes still a 2 ltr steve.
stu, im asking for someone else, cause there too lazy to do it
CR is 7.5
Inlet ports are 26mm
Current Cams are BD16 & BD14
Old Dec 20, 2005 | 02:22 PM
Mike Rainbird
Caraholic
Compression ratio is completely wrong for a start .
Old Dec 20, 2005 | 02:39 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Whats the lift and durtation on BD16 and BD14?
Compression dont seem wildly out to me, tho id go a lil lower and boost the fuck out of it.
Old Dec 20, 2005 | 02:43 PM
Ryan's Avatar
Ryan
thats what i said.
but its what the engine builder has done it to
Old Dec 20, 2005 | 02:57 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Originally Posted by Ryan
thats what i said.
well spec it yourself then, job done, only you to blame, thats what ive done
lift and duration of BD14 and 16s? Or dont people even know
Old Dec 20, 2005 | 03:08 PM
Ryan's Avatar
Ryan
not my engine steve.
will see if i can find out on the cams
Old Dec 20, 2005 | 03:17 PM
Mike Rainbird
Caraholic
thats what i said.
BD14 lift 8.9mm / duration 247°
BD16 lift 10.1mm / duration 265°
Old Dec 20, 2005 | 03:46 PM
Ryan's Avatar
Ryan
so any clearer? or still clear as mud
Old Dec 20, 2005 | 03:50 PM
...on those specs about 4.5k spin up...not bad at all really!
Old Dec 20, 2005 | 04:00 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
what you mean by spin up?
boost starts? or hits full boost by?
Old Dec 20, 2005 | 04:03 PM
Ryan's Avatar
Ryan
i would think starts steve, cant ever see it making full boost at 4.5k
would love it to though
Old Dec 20, 2005 | 04:09 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Id say it will be boosting way below there, but should have decent amounts of power (ie over 250bhp) by 4.5k, possibly 4k, shoudnt be too bad TBH, but full youd see by no more than 5 idve thought.
Old Dec 20, 2005 | 04:12 PM
Ryan's Avatar
Ryan
cheers for the advice steve, just trying to convince the new owner that the car will be a monster and not a lag monster.
also said it will piss 550bhp
Old Dec 20, 2005 | 04:20 PM
Mike Rainbird
Caraholic
Ryan,
But on a 2 litre lump it WILL be a lag monster , and contrary to whatever Phil says, the c/r will play NO part in spooling the turbo up any quicker.
My engine is 7.5:1 and below the boost threshold (3k) it is more dull than a wet weekend, even though it makes a 15psi by 3150rpm and full boost by 3500rpm....
Old Dec 20, 2005 | 04:22 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Doubt be much/any worse than a decent RS500 spec engine, so yeah, thats still technically laggy as fuck, but for the size of the engine its acceptable id say.
EDIT to say snap with mikes comments
Old Dec 20, 2005 | 05:24 PM
Mike high comp dont help spool up when did i say this? Hi comp gives better off boost responce...CAM choice helps spool up!
4.5k should be max boost on a 35 type roller bearing.
Old Dec 20, 2005 | 05:39 PM
Ryan's Avatar
Ryan
so it should be your average engine lag then, with more than your average BHP to match
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
escort-cossie-owner
Jan 5, 2005 08:51 PM
cozzie4d
Oct 7, 2004 12:56 PM
Mr C
Jul 28, 2004 05:58 PM
