erst starting
Old Dec 7, 2005 | 01:13 PM
kurdt5's Avatar
kurdt5
Default erst starting
The garage have had my car for 3 weeks but are lost, they still cant get the car started.
problem is we changed the head to a stage 2.
then when you try to start the car it goes to fire and then just turns over without a hint of firing up again.
leave for 5 mins and it will do the same.
any ideas?? im getting desperate as i aint had the car for 2 months and the garage are stuck.
Does this normally happen when changing erst heads?
Old Dec 7, 2005 | 01:16 PM
bigal1978's Avatar
bigal1978
take it to a good garage
Old Dec 7, 2005 | 01:17 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
agreed lol
Old Dec 7, 2005 | 01:19 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
plug leads in the right place?
is there fuel going in?
Old Dec 7, 2005 | 01:22 PM
david's Avatar
david
Have they bled the fuel through from the metering head ??
Old Dec 7, 2005 | 01:47 PM
kurdt5's Avatar
kurdt5
a good garage....true!!!
i mentioned this to them on the phone today about bleeding the fuel as someone mentioned this to me.
the fuel pump works fine and i plugged the leads with the diagram given to me from here somewhere.
to bleed the fuel do you need to undo the fuel lines to the m/head and have someone try to start the car until the fuel is flowing?
Old Dec 7, 2005 | 01:56 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
FUEL ACCUMULATOR?
The Fuel Accumulator maintains fuel pressure in the system after shutoff, ensuring positive re-start characteristics. A spring loaded diaphragm is compressed during pump operation. Upon shutoff, the spring pressure holds fuel pressure in the fuel system.
Old Dec 7, 2005 | 01:58 PM
kurdt5's Avatar
kurdt5
could be fuel accumulator.
just spoke to them stating i didnt bleed the fuel lines but they said with the fuel pump it would push the air out.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
