injector fitting kit??
Old Dec 5, 2005 | 10:06 PM
thedaddie's Avatar
thedaddie
Default injector fitting kit??
do i need a fitting kit for light blue injectors?
if yes, what is in the kit?
where can i get a kit from?
cheeRS dave
Old Dec 5, 2005 | 10:09 PM
twitchyrear's Avatar
twitchyrear
yes but you also need to modify somethin else
Old Dec 5, 2005 | 10:14 PM
thedaddie's Avatar
thedaddie
which is what, or do i have to guess
Old Dec 5, 2005 | 10:19 PM
Billabong's Avatar
Billabong
Pintle cap...........
Fitting kit (metal rings are interference fit):
Old Dec 5, 2005 | 10:56 PM
thedaddie's Avatar
thedaddie
thanks bong , my dad works for bosch so i'll get my injectors off him, where could i get a fitting kit from?
Old Dec 5, 2005 | 11:01 PM
Billabong's Avatar
Billabong
Mountune $$$ http://www.mountune.com/acatalog/C87368.html
PJ http://www.pjmotorsport.com/products...egory=fuelling
Or try the likes of A1, Woodford Garage Motorsport, Amber etc.
EDIT: (Stu only sells the kit with injectors)
Old Dec 6, 2005 | 05:13 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
Those yellow caps, are they also standard on yellow (standard) injectors???
Old Dec 6, 2005 | 05:16 PM
mk2rstaff's Avatar
mk2rstaff
they just dust covers are they not????
Billabong's Avatar
Billabong
That pic is just to show the position of the 'o' rings - you have to be very careful with pintle caps on light blues & greys.
The translucent blue ones are the 'dust covers.'
Old Dec 6, 2005 | 05:18 PM
....on my greys i dont run the caps!..and on the bottom i dont run the metal spacer i just run 2 o-rings!
Old Dec 6, 2005 | 05:21 PM
Chris Honeywell's Avatar
Chris Honeywell
well on mine i have run them with the caps untouched for the last 2 years
never had a problem
manuel boeckx
13
Oct 3, 2015 02:29 PM
Porplus12
Sep 10, 2015 07:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Perfmr2
Aug 6, 2015 07:30 AM
