ECU / Lambda Sensor Wiring
Old Dec 5, 2005 | 06:27 PM
Neil S's Avatar
Neil S
Default ECU / Lambda Sensor Wiring
I'm in the process of fitting a Stage 3 closed-loop fuelling kit from Stu, and could do with a couple of bits of info
My car is a red-top 4x4, but the loom has a lambda sensor connection on the drivers side chassis leg. I've cleaned up the plug and put a meter on it. As far as I can tell, the wires are:
BN - Earth
BK - Heater +ve
BN/WH - Signal
Is this correct?
The other thing I could do with is an ECU pin-out diagram. I seem to remember there was one in the destructions for my SECS monitor, but god only knows where that is!
Can anyone help?
Cheers!
Neil.
Old Dec 5, 2005 | 06:29 PM
Ryan's Avatar
Ryan
Pin 2 is signal on the ECU for the lambda
SECS wiring is:
PIN 8 (BLACK) > ECU PIN 1: GROUND
PIN 7 (RED) > ECU PIN 20: 12V POSITIVE SUPPLY
PIN 5 (PURPLE) > ECU PIN 25: IGNITION SIGNAL FOR RPM READING
PIN 4 (GREEN) > ECU PIN 17: THROTTLE POSITION SENSOR
PIN 3 (BLUE) > ECU PIN 29: ENGINE COOLANT TEMPERATURE SENSOR
PIN 2 (YELLOW) > ECU PIN 31: AIR CHARGE TEMPERATURE SENSOR
PIN 1 (WHITE) > ECU PIN 15: MAP SENSOR
Old Dec 5, 2005 | 06:32 PM
Neil S's Avatar
Neil S
Cheers Ryan - I was after a full pinout for the ECU tho!
Then I can see end of the plug to count from
Neil.
Old Dec 5, 2005 | 06:35 PM
Ryan's Avatar
Ryan
Pin 1 starts at the open end of the plug.
pin out is :
1 POWER GROUND
2 LAMBDA SENSOR INPUT
3 CRANK SENSOR GROUND
4 CRANK SENSOR INPUT
5 PHASE SENSOR GROUND
6 KNOCK SENSOR GROUND
7 PURGE VALVE
8 DIAGNOSTIC SOCKET
9 VREF MONITOR
10 POWER RELAY EARTH
11 VREF NEGATIVE
12 WARNING LAMP OUTPUT
13 OCTANE ADJUST
14 OCTANE ADJUST
15 MAP SENSOR INPUT
16 BOOST VALVE
17 THROTTLE POSITION
18 INJECTOR 4
19 POWER GROUND
20 POSITIVE SUPPLY
21 NOT USED
22 KNOCK SENSOR INPUT
23 PHASE SENSOR INPUT
24 IGNITION TRIGGER GROUND
25 IGNITION TRIGGER OUTPUT
26 SPARE
27 DIAGNOSTIC SOCKET
28 FUEL PUMP RELAY
29 COOLANT SENSOR
30 VREF POSITIVE
31 CHARGE AIR SENSOR
32 INJECTOR 2
33 INJECTOR 3
34 IDLE SPEED VALVE
35 INJECTOR 1
Old Dec 5, 2005 | 06:48 PM
Neil S's Avatar
Neil S
Spot bollock on dude!!!
Cheers for the help the other day on the fuel pump connections
I dont suppose you know where I can get an amal-type connector do you? Mine's dead and I don't fancy pony spade connectors
Neil.
Old Dec 5, 2005 | 06:51 PM
Ryan's Avatar
Ryan
Farnell Inone
Old Dec 5, 2005 | 07:02 PM
Steve Escos's Avatar
Steve Escos
Ryan, Dont suppose you have a pin out for a p8 loom do you?Steve
Old Dec 5, 2005 | 07:03 PM
Ryan's Avatar
Ryan
no different mate
Old Dec 5, 2005 | 07:08 PM
Stu @ M Developments's Avatar
PassionFords Creator
If you have any problems Neil, dont hesitate for one second to call me. The price of the Software obviously includes after sales support so feel free to use it.
Old Dec 5, 2005 | 07:09 PM
Ryan's Avatar
Ryan
Good Call Stu.
Top Service as always
Old Dec 5, 2005 | 07:28 PM
Neil S's Avatar
Neil S
I'd expect no less!
I'll give you a bell if I get any questions specific to your kit... Just getting the more general stuff out of the way before I trouble you
Neil.
Old Dec 5, 2005 | 07:48 PM
The Youth.'s Avatar
The Youth.
neil I have your secs instructions in my desk at work!!!
you lent me them about 18 months ago!! lol
steve
Old Dec 6, 2005 | 06:28 AM
Neil S's Avatar
Neil S
Christ! I must have been pissed, cos I have zero recollection of that!
Neil.
Old Dec 6, 2005 | 09:13 AM
To Confirm:
    Hope this helps.
    Old Dec 6, 2005 | 09:16 AM
    Beach's Avatar
    Beach
    Stu im interested in this closed loop fueling you do, whats needed to fit it to my saph running l6...
    Im going to be changing it to l8 very soon
    Old Dec 6, 2005 | 09:28 AM
    In a nutshell....
    Ł250 for the hardware key & software.
    Ł80 - Ł180 for a lambda sensor depending on options.
    Ł20 for teh stainless steel boss for teh exhaust.
    Ł20 to weld it into teh downpipe if you dont want to do it prior to teh visit.
    Ł50 to wire the lambda into the management system to get the signal and heaters working.
    This will give you total closed loop fuel control.
    Bear in mind i dont do the sofware off teh shelf for any larger than 803s. If you want 400s or larger i will ONLY live map it.
    Old Dec 6, 2005 | 09:31 AM
    Beach's Avatar
    Beach
    In a nutshell....
      Bear in mind i dont do the sofware off the shelf for any larger than 803s. If you want 400s or larger i will ONLY live map it.
      Cheers Stu...
      My downpipe allready has the lambda boss just before the bend near the turbo, would this work ??
      Also i have 400's so would require a live map aswell.
      Are there any benifits of this sytem Stu ??
      Old Dec 6, 2005 | 09:54 AM
      Yes, if its an M18x1.5 boss it will be fine.
      For benefits i will BTTT another topic that deals with this allready to save time.
      Old Dec 6, 2005 | 10:10 AM
      Ive sent a topic up, but this one may actually be more usefull to you:
      https://passionford.com/forum/viewtopic.php?t=66761
      DixieTheKid
      11
      Jun 6, 2020 11:20 AM
      TPM961
      Jan 15, 2018 10:50 AM
      DixieTheKid
      Sep 14, 2015 09:04 PM
      tib2220
      Sep 14, 2015 12:33 PM
      Si B
      Sep 12, 2015 06:49 AM
