Sky+ Again......
Old Nov 27, 2005 | 06:56 PM
BillyCabrio's Avatar
BillyCabrio
Default Sky+ Again......
What format do the Sky+ boxes save recording as?
Old Nov 27, 2005 | 07:14 PM
BillyCabrio
Old Nov 27, 2005 | 08:55 PM
BillyCabrio
Someone? Anyone?!!
Old Nov 27, 2005 | 08:56 PM
Benn 304R's Avatar
Benn 304R
no one cares
Old Nov 27, 2005 | 08:58 PM
BillyCabrio
I do!
PMSL!!!
Old Nov 27, 2005 | 09:44 PM
Spiky's Avatar
Spiky
linux
Old Nov 27, 2005 | 09:47 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
What do you mean ? As in saved on the hard drive ?
It's a proprietary format, I am not aware that anyone has managed to get any useful data off the drive if that's what you are trying to do
Old Nov 27, 2005 | 09:50 PM
Fil's Avatar
Fil
ELASTIC BAND
can you not remove the hard drive and plug it in to your pc, like other satellite recievers then?
Old Nov 28, 2005 | 08:34 AM
BillyCabrio
Another thing i was wondering about, i've had the lid off and it looks the same, same connections etc....
I was also curious that if i'm going to transfer data i.e. films etc.... from the Sky+ hard drive to the pc's hard drive will i need to convert it to something else so i can watch it once burnt to a dvd?
Will the pc understand linux?
Old Nov 28, 2005 | 09:01 AM
tonyk's Avatar
tonyk
The only way you are going to do this is to buy a video capture device and hook the sky box up to it. The hard drive is encrypted and in skys own native format. I have not seen anything that can read this format. There may be something out there but its doubtful.
Old Nov 28, 2005 | 09:46 AM
BillyCabrio
tonyk
Done that mate, i have a nice tv card and a nice phat hard drive too
With regard to the format.... Sky actually say that you can copy what you have recorded onto a dvd burner direct from the Sky+ box, if thats the case does the box reformat into a dvd readable format?
Otherwise whats the point if the dvd player can't even read it when you try to play it?
Old Nov 28, 2005 | 02:25 PM
tonyk's Avatar
tonyk
Billy when you use the copy to feature, it just displays it as a picture, in the dvd burner is hardware which just encodes the video picture into dvd format in realtime mode. All the ports do on the sky box is output the picture, the tv displays it or in this case the dvd player encoded it to dvd format.
Old Nov 28, 2005 | 02:27 PM
BillyCabrio
So what happens to the sound?
Old Nov 28, 2005 | 02:29 PM
rsdene's Avatar
rsdene
not sure about copying it put sky box's use a normal computer hard drive
Old Nov 29, 2005 | 02:09 PM
frog's Avatar
frog
If you put the hard drive into a computer it will be gobbledegook to the PC !!! It's not because it's a hard drive that the data on there is readable by a computer. Well, it could be, if someone had figured out how the skybox records onto the hard drive.
So far, as far as I know, it's safe as houses and you won't get your mitts on the data... DVD backup is the only solution.
Old Nov 29, 2005 | 02:18 PM
Porkie's Avatar
Porkie
My Sky+ is like Satnav... its great 90% of the time but when you REALLY REALLY need it to work, it will lock up, fail or throw a paddy of some sort
Old Nov 29, 2005 | 02:48 PM
adamS2RST's Avatar
adamS2RST
I had it installed Friday. (Was a big install of 1 X + box and 2 X Digibox's with mutliroom) So far very happy with it no major problems I've noticed the + box ticks a bit and the fan comes on every few hours but goes off after a short time, from what I understand this is normal. But it's recorded all my programs I missed over the weekend and loving the pause and rewind
Old Nov 29, 2005 | 03:42 PM
Taylor's Avatar
Taylor
If you are wanting to take stuff from you sky+ box and put it on to disc,can you not just plug in a recordable dvd player into the back of the sky+ box with a scart,then go to your sky+ planner highlight what you want to record,then hit the red button on you remote for the copy option?
Old Nov 29, 2005 | 03:47 PM
TIFF's Avatar
TIFF
Chasing Radders
Mine is being fitted tomorrow
Old Nov 29, 2005 | 03:51 PM
Phil's Avatar
Phil
Jeebus
You have to play it and record in real time using a DVD recorder, much like recording live tv onto a DVD.
Old Nov 29, 2005 | 03:58 PM
cozzed's Avatar
cozzed
sky + rocks
Old Nov 29, 2005 | 04:00 PM
FasterFords's Avatar
FasterFords
Sky+ costs too much, better to get a DVD + HD recorder, then you can keep stuff you want by burning it to DVD.
mcst
Jan 23, 2009 08:58 AM
Minirotty
22
Nov 21, 2008 10:15 PM
smudge_lad
24
Dec 13, 2007 12:59 AM
smudge_lad
41
Nov 8, 2007 06:08 PM
Zetec Andy
47
Nov 14, 2005 05:14 PM
