Gutted and need advice from engine builders
Took head apart to change tappets today and got worried when I found this
And this
Thinking I may have to get a new pair of cams, but OH no much worse was to follow
So thats twice a sweat running engine I've bought has been less than useable
(<real tears)
Can anything be done with it or is it new head time
Thinking about putting the 1.8 back in again
And this
(<real tears)Can anything be done with it or is it new head time
Spiky dunno why oil is that colour prob just the camera flash
fudgeass I beginning to think you may be right
I've asked Mark from MAD to take a look and see what options I have
Don't panic mate... My cam bearings were worse.
After advice from both stu and Karl, I gently dressed the bearings and caps off wit 1000grit, then built them up again.
I think what Karl said was to do this, put it back together without tappets, then see if there was any play in the cam bearings. If not, then it's all good.
It's probably picked up on start-up the last time the cams had been out.
I reckon its caused by the shape of the cam bearing - it kind of wipes the oil off as the cam turns. When I rebuilt it, I filled the engine by pouring oil directly over the cams before putting the cover back on
Neil.
Neil.
if its a 4x4 the oil feed for the turbo is straight out of the gallery that feeds the lifters and starves the lifters of oil as it takes the path of least resistance i bet that is the exhaust side i would use the head again by dressing them up as karl/stu said
Originally Posted by Neil S
Ahhhh! I've heard people say that the 2wd oil feed is better, but no-one has ever explained why!
Neil.
Neil.
it always seems to be the exhaust side that cops it other explanation maybe the engine has run low on oil I SAY LOW not OUT as a yb can nearly hold the sump contents higher up the engine so oil becomes scarse and the furthest point cops it been the exhaust cam/turbo
dip the oil and see it could have been done for ages though u never know
i bet its picked up on numbers 2 and 5 cam caps on there
mine did a similar thing, but only lightly scuffed the bearing and didn't damage it, cleaned it up with some 1200 grit and then washed it down with white spirits and all is good
just remember to put it back together wet - ie, with camlube or molygrease otherwise it'll do the same again within a few hundred miles.
yours looks like someone has removed the cams previously and either replced them dry or there has been a bit of dirt on the cap, so when replaced and started, its worked its way round
Also, the problem could be from someone putting the camcaps on backwards - IE, numbers 1 to 5 on the inlet and 6 to 10 on the exhaust, when they are supposed to be 1-5 on the exhaust and 6-10 on the inlet, with 1 and 6 been the roller bearing caps at the front of the engine
alternatively, as a modification, you could use a lathe and add an oil groove to the cam where the bearings sit - a bit like the inlet cam.
altho, according to the cosworth techy book, "due to the design of the cam bearings and cams, and the positioning of the lubricator on the exhaust cam, an oil groove is not required"
obviously it might be required to stop the caps and cam chewing themselves senceless
Well I've cleaned up the head and cap, tried cam back in and its loose as hell, tried inlet cam in its place and its fine, then I put exhaust cam in inlet side and its loose as hell so I'm going to replace the cams and keep everything crossed
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
