Boost Problem
Old Sep 13, 2005 | 01:07 PM
davidnormanuk's Avatar
davidnormanuk
Default Boost Problem
Hi all,
I have just fitted a -31 actuator to my RST with a bleed valve. Due to me having a chipped ECU I wanted to run the boost at about 15PSI but at the minute all I seem to get is 10PSi max. I have adjusted the actuator and played around with the bleed valve but can't get it to go over 10 PSi when I want it to. The other problem is I took the car out the other night and it went to 17PSi without changing anything. Any siggestions as to what the problem could be?
Dave
Old Sep 14, 2005 | 08:23 AM
davidnormanuk
Sorted it. Now running 18PSi and alls good.
Old Sep 14, 2005 | 08:27 AM
Robin's Avatar
Robin
what was the problem
Old Sep 14, 2005 | 09:55 AM
davidnormanuk
It was a problem with the amal valve. Sorted that out and took it for a blast and crapped myself. It was boosting at 20psi and there was no detonation or anything. Brought it down to a safe level as I don't want to fry my engine. What can I go up to on standard rods and low comp bottom end?
Dave
Old Sep 14, 2005 | 09:56 AM
davidnormanuk
Forgot to mention its running a hybrid turbo with 360 degree bearing on MFi.
Old Sep 14, 2005 | 10:59 AM
mart.rs's Avatar
mart.rs
should be able to cope with up to 22 psi safely providing its been set up correctly! you can get more just all depends on the spec really!
Old Sep 14, 2005 | 12:59 PM
davidnormanuk
It pulls like a train at 18PSi so I'll leave it at that and get it on the rollers to check everythings ok.
Dave
Old Sep 14, 2005 | 05:09 PM
Manchester Mike's Avatar
Manchester Mike
What boost was you running previous? Has the fueling been set up to match the increase in boost?
Old Sep 15, 2005 | 07:41 AM
davidnormanuk
I was running 18PSi before on my old ECU which turned out to be knackered. So everything should be fine but gonna get it checked out just to make sure its right. There's a place in wakefield somewhere thats does it. Does anyone know the name of it and where abouts it is?
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
