understeery lil so and so
Old Sep 9, 2005 | 04:28 PM
Dave Henshall's Avatar
Dave Henshall
Default understeery lil so and so
what can i do to make my escos turn in sharper without liftoff oversteer into fasy tight corners, forgot how "safe" the std suspension is, its running 18's with the right offset and fully poly bushed throughout, would fitting a set of ajsutable front TCA's be able to dial in a bit more turn in bite, if so , how many degrees camber should they be set to?
Old Sep 9, 2005 | 11:59 PM
Azrael's Avatar
Azrael
If you are really desperate you can set it toe-out 1-1,5 degrees. Might be a little bit tricky though... and will eat through tires quite quickly.
Old Sep 12, 2005 | 08:46 AM
Dave Henshall
found a odd wheel on the near side rear,,, could explain a bit,
Old Sep 12, 2005 | 08:53 AM
Azrael's Avatar
Azrael
Borrow wheels from someone and try it then...
andre_k
23
May 4, 2005 11:18 AM
Maria.
49
Mar 11, 2005 09:39 AM
rs_daz
Nov 14, 2004 05:02 PM
