RS WIRING PROBLEM PLZ HELP
Old Sep 2, 2005 | 10:54 PM
Dan Cossie's Avatar
Dan Cossie
Default RS WIRING PROBLEM PLZ HELP
After turboing my xr3 last weekend....i had an alternator problem which you guys on here helped me fix cheers.
And now i went to start the bloody thing to hear the fuel pump not just priming but constantly stayin on wen you turn the key and the fuel pump relay clicking.......
So i thought i wud have a look at the relay to see if it has burn out or somethin only to find that some complete idiot has cut the wires and stuff and put a wire from the red connector to the yellow connector and they look like they may have burnt together...
So does anyone know of what colour wires i need to put in were and also if thats bad them bein put together???or shud i leave them and just replace the fuel pump relay??
Old Sep 3, 2005 | 03:01 AM
SafeChav's Avatar
SafeChav
hello
what engine u dropped in, an RST i presume. The fuel pump relay only really serves to switch the higher current draw, and as a safety device to cut off fuel circulation if the engine stops running. Up to you if you want it to operate as factory ones do, no performance loss if you decide not to.
With regards to wiring.....a YELLOW wire?????
I've wired two of my own cars and yellow wires dont usually go anywhere near the fuel pump relay. Yellows ive seen are either for the headlights, and auxiliary ignition position I.
to help i need to know what engine you've put in, and if its an RST lump, whether its EFI or MFI
Old Sep 10, 2005 | 10:51 AM
Vampire's Avatar
Vampire
hi safe chav, i think you might be able to massivly help me!
ive got an escort mk5 with an rs turbo lump conversion. the whole loom was a mess so im replacing it.
exactly what wires are needed to get the turbo lump running? and where do they go? any help appreciated, thanks
Old Sep 10, 2005 | 11:04 AM
SafeChav's Avatar
SafeChav
add me to msn if you have it, can talk to actively then rather than all this posting
Old Sep 10, 2005 | 08:24 PM
Vampire's Avatar
Vampire
you on msn?
Old Sep 30, 2005 | 07:51 PM
SafeChav's Avatar
SafeChav
you on msn?
alright mate
have u sorted it yet? if ur still havin probs add me to ur msn safechav@hotmail.com and i'll help u out
Old Oct 1, 2005 | 11:35 AM
Vampire's Avatar
Vampire
i got it fixed, but i could still do with know what wires i do and dont need! as i have a amassive bundle under my dash that i dont know if i can remove.
Old Oct 1, 2005 | 12:26 PM
SafeChav's Avatar
SafeChav
ok well have u got msn? gona be a challenge on here otherwise
The Enigma
Sep 12, 2015 10:12 PM
Si B
Sep 12, 2015 06:49 AM
ward1174
Sep 12, 2015 03:34 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
routemaster
Sep 7, 2015 05:27 PM
