Smoking ERST
Old Sep 1, 2005 | 02:26 PM
cul's Avatar
cul
Default Smoking ERST
blue smoke!!!!!!
1.8 zvh escort rs turbo.
when started on idle no smoke.
when reved from idle blue smoke.
when accelerating on the road blue smoke.
when accelerating very hard loads of blue smoke.
when i back off after boost no puffs of smoke.
10 bar reading for compression in all cylinders.
no oil leaks,
all plugs in fairly mint condition.
no oil in any boost hoses or intercooler or dump valve.
loosin enough oil in a week to visibly see on dipstick.
is it possibly the turbo oil seal on the exhaust side sucking oil and leaking into the exhaust and burning it???
or is it valve stem seals ????? even tho they are brand new!!!!
or a piston ring??
help for the love of god
Old Sep 1, 2005 | 03:48 PM
rodney's Avatar
rodney
sounds like rings mate , only other possibilty bein the seals on the turbo shovin oil out the exhaust , check there aint any oil in the down pipe where it bolts to the turbo,.
Old Sep 1, 2005 | 03:55 PM
SafeChav's Avatar
SafeChav
hello mate
sounds like an odd one ive got a similar problem. my engines done 3.5k on a rebuild, been parked up for 2 months, ive re-built the turbo, and started it up....blue smoke so my first though was B*LLUCKS ive fucked the turbo, but now ive found oil coming through the exhaust prt on the head for number 1, very odd, the turbo is fine, can't be rings it had brand new 0.5 over size mahle pistons.
are all your compressions equal, and how many miles has the engine done? I'd say turbo, but u never can tell without looking at it.
anyone got any ideas on my problem, just one cylinder with oil in the exhaust port
Old Sep 1, 2005 | 04:24 PM
cul's Avatar
cul
my engine is just fully rebuilt with new ring valve seals and a secondhand turo from ebay with NO play at all( but seals could still be gone.
all compressions are equal , they all go to 10 bar after the third rotation of the engine.
In your case safechav i would say that the head gasket to oil way is leaking into your cylinder number 1. onlyway to find out is off with the head.
is the plug in cylinder 1 wet or oily??
Old Sep 1, 2005 | 05:55 PM
GrimmeRS2K's Avatar
GrimmeRS2K
id say turbo aswell, ive had a turbo before with no play, but it smoked,
secondhand aswell mate, unless its brandnew or seen running on a car ur never gonna know!
Old Sep 1, 2005 | 07:27 PM
SafeChav's Avatar
SafeChav
DEFINATELY TURBO, eBay is full of skanking b*stards. The bearings are more than likely fine, but u cant tell if the oil seals are gone or not. Get yourself a service kit should sort it out, if uve re-built u may aswell do the turbo too, saves messing about later on.
Yeah i agree with what your saying, but the engines done 3.5k i just can't see it, not one bit of smoke before i parked it up, been sat for i'd say 2 months, shouldn't cause problems. Not a happy bunny
Old Sep 1, 2005 | 07:29 PM
SafeChav's Avatar
SafeChav
oh and yeah the plug has a little oil on it (all be it clean oil though )
Old Sep 2, 2005 | 12:18 AM
cul's Avatar
cul
i hope its the turbo cause im paying out for a new one as soon as i can afford it.
Old Sep 2, 2005 | 12:19 AM
cul's Avatar
cul
if the plug had oil on it , it has to be either a ring or a valve seal on that cylinder.
did you happen to squeeze the gasket twice????
Old Sep 2, 2005 | 04:05 PM
SafeChav's Avatar
SafeChav
I expect it will be, one thing u could do but i really don't like suggesting it so PLEASE PLEASE PLEASE don't hold it against me....
you could try removing theoil feed from the turbo (and blocking it obviously unless u want your engine rust proofed), and then start and run the car. Obiously with no pressurised oil entering the turbo, thiw sill determine if the turbo is making the smoke? DONT WHATEVER U DO DRIVE IT LIKE IT, that would be suicidal, the turbo's going to spin even on tick over only about 4 rpm, so don't do it for too long, but this should help u reach a decision, and if not the turbo should still be ok as loing as u DONT DRIVE IT OR REV THE CRAP OUT OF IT.
when u say squeeze the gasket twice?? do u mean the torquing sequence of the head bolts?
yeah i agree, ive got to change the cam as i was giving it a good old thrashing, a few days before i took it right round to the rev limiter in 5th (130+, sh!t scary), then about a week later i was having a good run down a country road n a lobe went on the cam, hence the reasing for parking it up, so anyways when i do that i'll check the stem seals but they were brand new when the new valves were fitted on the head.
Mc5506
Oct 5, 2015 09:57 PM
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
A.t.p
Sep 29, 2015 05:04 PM
