car jumps out of fifth gear over 100mph ?????
Old Jun 29, 2004 | 06:42 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default car jumps out of fifth gear over 100mph ?????
why is it ?????
thinking the syncro might be fooked in fifth gear
happened once but i had to slow down, change to forth for a bit then back in fifth and its not done it since
anyone got any ideas ?????
Old Jun 29, 2004 | 06:43 PM
Demondave's Avatar
Demondave
Mine does it in third some times
Old Jun 29, 2004 | 06:47 PM
Shings's Avatar
Shings
the selector in the end of the box is shafted- I have a box sitting down the side of my house that does it.
You might get away with adjusting it- I replaced mine and it fucked it again after a while.
Old Jun 29, 2004 | 06:49 PM
Ginge !'s Avatar
Ginge !
what causes it out of interest ????
i dont drive it hard and the guy who owned it before drives like a mini cab driver
Old Jun 29, 2004 | 06:50 PM
Shings's Avatar
Shings
I think its all starvation at the end of the box that causes em to over heat and fuck up.
Old Jun 29, 2004 | 06:54 PM
Ginge !'s Avatar
Ginge !
ok it maybe a bit low on oil, was ment to put some in n friday at work but i forgot
oh and it happened after doing 110 to 120 on m1 for about 20 mins, seemed to be a bumpy road too ( after junction 28 when it gets quiet )
Old Jun 29, 2004 | 06:57 PM
Shings's Avatar
Shings
Also another possible cause could be shagged linkages or shagged engine mounts.
HAnds on the plenum and rock the engine front to back to see how bad they are- shouldn't move a massive amount.
The reason they get all starvation is because its a bit bolted on the end of a 4 speed box- Fords cheapo 5 speed money saving
Old Jun 29, 2004 | 07:03 PM
Ginge !'s Avatar
Ginge !
it aint the mounts, deffo as i would hav poped a drive shaft the way i rag the fooker through the gears
the linkage it what i was thinking but it feels tight and nice, not slopy like most escorts
fooking cars, why cant they be driven hard and not fook up
Fordmad!
Sep 26, 2015 05:24 PM
knight19770
Aug 4, 2015 12:36 PM
RIB1122
Aug 3, 2015 09:20 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
