Would a Transit MT75 box fit a cossie ?
Old Aug 25, 2005 | 09:19 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Would a Transit MT75 box fit a cossie ?
Are they the same box ?
Old Aug 25, 2005 | 10:28 PM
DazC's Avatar
DazC
No....nothing like at all...
Old Aug 25, 2005 | 11:57 PM
sailorbob's Avatar
sailorbob
The rwd MT75 gearbox is essentially the same as the MT75 4x4 gearbox, the difference being that the 4x4 box has a transfer box stuck onto the end.
Old Aug 26, 2005 | 07:50 AM
frog's Avatar
frog
sailorbob makes sense, could you use the transit rwd box and mate it to a transfer box ?
Reason I ask, is that transit boxes are cheap as chips compared to cossie ones... Ok, they are probably past their best, but it could be a useful source of spares
Old Aug 26, 2005 | 08:56 AM
DazC's Avatar
DazC
Old Aug 26, 2005 | 10:57 AM
frog's Avatar
frog
so 50/50 then... Any more takers ???
Old Aug 26, 2005 | 02:04 PM
DazC's Avatar
DazC
The casings are totally different.
The bell housing on a Transit is about 1 and 1/2 times bigger in diameter than the Cossie. It is also cast in to the rest of the box and has a COMPLETELY different bolt pattern and the starter is on the wrong side. The bellhousing looks massive on a Transit.
The gear linkage on a Cossie is a rod poking out of the back of the box and onto a frame bolted to the transfer box with 4 M8 bolts, the Transit is a turret on top of the box where the stick drops difectly into the top of the box and is held in by 3 Torx T40 bolts.
The reverse light switch on the Cos is a sensor bolted to the top left hand side of the box and when removed, leaves a small opening. The Transit is an actual screw in switch.
The Transit has a speedo drive where as the Cossie box doesn't so the shafts may not mate to the transfer box.
Clutch splines may be another issue.
If you want pictures I can get them for you...
Old Aug 26, 2005 | 02:05 PM
DazC's Avatar
DazC
The new Transit MT75 box is different again....
Old Aug 26, 2005 | 03:48 PM
frog's Avatar
frog
Cool, thanks DazC, no pictures required, your explanation is clear enough
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
matman
Sep 9, 2015 05:45 PM
Mark RS
14
Aug 11, 2015 11:45 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
