HELP. Fuel pump problem in sierra cosworth
can anyone tell me,which relay switch or fuse is for the fuel pump is it inside the car or under bonnet . my fuel pump wont work when i turn on the ignition its not the pump itself as i put power straight to it and it works.tried all fuses and none seem to be blown.where else could the problem be any help please . or a small diagram of the fuse box might help.
Thanks john
Thanks john
Have you checked the fuel cut off switch?
Maybe there's a problem with that.
A mate of mine had the same problem with his car neither of us could find the fault. Checked the relay and fuses nothing wrong with them.
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
155lee
Aug 14, 2015 11:21 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
