new samco boost hoses, problem
Old Jul 22, 2005 | 10:28 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Default new samco boost hoses, problem
hi, fitted some new samco boost hoses today after my old ones were looking a bit tired, i noticed that the one what goes from the inlet of the turbo to the metering unit, looked abit squashed in the middle, anybody else has this problem, car boosts ok, but dont like the look of it!
Old Jul 22, 2005 | 11:19 PM
turbo.jon's Avatar
turbo.jon
had a problem with that 1 on mine when i last had it set up car would not boost no more than 14 psi as hose was on wrong way round but if u have not got no probs it must be ok it do look like its on wrong though..
Old Jul 23, 2005 | 01:36 AM
rs_daz's Avatar
rs_daz
Had this on mine m8.. All i did was trim about 1cm off.. it helped abit but still looked abit kinked....crap ey
Old Jul 23, 2005 | 07:50 AM
Turbo-T34's Avatar
Turbo-T34
had problem like this with mine, had to also cut about 1-2cm off to make it fit properly.
Also the little tiny bit of samco that goes from the crossover pipe (attached to the rocker cover) onto the inlet manifold was far too long, ended up cutting it in half to make it fit and look nice!
Strange when they say these things are an exact fit replacement!
Old Jul 23, 2005 | 09:50 AM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
mine looked a bit kinked too, sum 1 has trimmed it b4 tho, and it needed rotating slightly to make it a smooth fit
Old Jul 23, 2005 | 10:14 AM
AJC's Avatar
AJC
mine kinked, not been trimmed and boosts 18psi no problem
Old Jul 23, 2005 | 10:30 AM
AKRS1's Avatar
AKRS1
mines is a bit squashed in the middle but boosts to 18psi without no problems
Old Jul 23, 2005 | 10:33 AM
Micky's Avatar
Micky
Yeah had the same prob,just trimmed the end's a bit,easy .Regards Micky
Old Jul 23, 2005 | 10:38 AM
GrimmeRS2K's Avatar
GrimmeRS2K
yeah i had to trim my old ones a bit, but didnt think i would have to as they say direct replacement!
thanks for your help lads
Old Jul 26, 2005 | 12:37 PM
John Laverick's Avatar
John Laverick
Don't forget this hose only fits on one way!!! Its very easy to get it fitted back to front which will end up kinking it in the middle.
If you notive the inlet to the turbo is on an angle upwards...if you hold the hose up ni the air it will become obvious which way round it fits!! [Although you may STILL need to do some trimming]
Old Jul 26, 2005 | 12:45 PM
220TC's Avatar
220TC
mine kinked as well when I fitted it I have put 3 jubilee clips around the kinked area and this has sorted it, lovely and round now
Old Jul 26, 2005 | 10:21 PM
steve90spec's Avatar
steve90spec
i had same prob went to a friend and got him to make up some stainless steel tubing , cut the hose in half ,and fitted the steel tube inside the hose problem solved and no kinked hose + it dont collapse under high boost anymore ( 18psi)
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
markk
Sep 9, 2015 08:11 AM
hopper350
Sep 4, 2015 12:53 AM
