ecu diagnostics trouble codes zetec 1.8
Old Jul 13, 2005 | 08:55 PM
k-cey's Avatar
k-cey
Default ecu diagnostics trouble codes zetec 1.8
ive just used a scanner on my orion. it came up with a code said sumting bout cylinder identification open circuit. (cid) anyone no wot it means as i dont have manual with trouble codes in help will b greatly appreciated
Old Jul 14, 2005 | 11:40 AM
sailorbob's Avatar
sailorbob
Can you post the code number? CID is the camshaft sensor for identifiying when cylinder #1 is at TDC. Open circuit usually means a duff sensor, disconnected sensor or failed part of the circuitry in the ecu that is associated ith the sensor.
Old Aug 3, 2005 | 09:34 AM
k-cey's Avatar
k-cey
got it sorted last owner put new leads on wrong way when i put them rite confused ecu disconnected battery all ok almost
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
