Intermittent boost problems
Old Jun 21, 2005 | 01:37 PM
tubbykev's Avatar
tubbykev
Default Intermittent boost problems
right then here goes.....
.... i will be driving along in 4th gear and then plant my right foot, but as soon as the rpm reaches about 4000rpm it seems to hesitate and stop pulling but after a few seconds then go again. Also sometimes it wont boost at all
anybody got any ideas???
cheers for the help peeps
Old Jun 21, 2005 | 10:46 PM
addiction's Avatar
addiction
sounds like you may have an actuator problem there!
Old Jun 21, 2005 | 11:03 PM
AKRS1's Avatar
AKRS1
I had this problem before and it turned out to be my metering head.
Old Jun 21, 2005 | 11:28 PM
GrimmeRS2K's Avatar
GrimmeRS2K
check your bottom boost hose isnt soft, the one into the metering unit, when the turbo sucks this pipe can collaspe causing your problem
Old Jun 22, 2005 | 10:15 AM
tubbykev's Avatar
tubbykev
cheers peeps, will have a look at them all
getting new actuator soon anyway with Motorsport Developments stage 1 kit
JK12
33
Apr 26, 2021 12:09 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
