help needed cvh engine build question
Old May 25, 2005 | 12:05 PM
xr4x4rs's Avatar
xr4x4rs
Default help needed cvh engine build question
hello peeps
need a pic or explaination on wich way round the conrods go
i.e into sequence 1234
does the curve at the bottom of the rods face each other
and the looking at the two middle rods should be straight
if you know what i mean
cus im buggered if i know also no diagrams in haynes
thanks for the help
Old May 25, 2005 | 12:16 PM
Philly's Avatar
Philly
If your talking about std. rods they have an F which stands for front...
So the F should point towards the Oil pump end of the engine.
Old May 25, 2005 | 12:25 PM
xr4x4rs's Avatar
xr4x4rs
they are standard rods mate
they have been polished and shotpeened
never noticed a f on them will take a look tomorrow when im back down there
have u got a pic or diagram or anything i can relate to
thanks
Old May 26, 2005 | 01:26 AM
xr4x4rs's Avatar
xr4x4rs
Old May 26, 2005 | 08:48 AM
JesseT's Avatar
JesseT
Default Re: help needed cvh engine build question
Originally Posted by xr4x4rs
hello peeps
The larger hole comes down to the crank and the smaller up to the pistons.
There for sure is a "F" halfway the rod that should face the oil pump. If you have pistons attached, then the larger cutout is for the inlet valve, so that shoud face the oil filter side.
Old May 26, 2005 | 09:57 AM
THE RS DJ's Avatar
THE RS DJ
What is the reason for front and rear?
Why do the rods have a fr and rr.??
Whats different about them???
Anybody?
Old May 26, 2005 | 11:28 AM
JesseT's Avatar
JesseT
Oil spray holes e.g. are on one side only.
Old May 26, 2005 | 11:49 AM
zvhturbo's Avatar
zvhturbo
The small groove that the bearings sit into should be on the inlet side as well if that helps out.
Matt.
JoeyBoyden
Jan 4, 2024 02:36 PM
Sultzi
12
Aug 16, 2015 01:08 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
knight19770
Aug 4, 2015 12:36 PM
