Found out why my car lost all her power.....
Old May 14, 2005 | 12:35 PM
RSKim's Avatar
RSKim
Default Found out why my car lost all her power.....
I had about 4 nuts missing off my inlet manifold, and loads other were loose
Anyone know why this would happen, they were DEFO tightened up when we put the engine in AGGGGEEESSSS ago
Old May 14, 2005 | 12:36 PM
Niall.b's Avatar
Niall.b
bet they were the bottom ones.
Old May 14, 2005 | 12:38 PM
RSKim's Avatar
RSKim
bottom and top, 2 from top rest from bottom
MrsFrog's Avatar
MrsFrog
You used Locktite?
Old May 14, 2005 | 12:39 PM
Toe Knee's Avatar
Toe Knee
Obviously not tightened up properly enuff then u donut
Possibility is the bracket that bolts the throttle body to the engine mount, if the bracket, or the bolt isnt there you will get more vibrations which COULD have loosend the nuts over time, spec the way u drive
Old May 14, 2005 | 12:40 PM
boost mad's Avatar
boost mad
turbo damper not set up properly ? ( if it 2wd ). just a guess
Old May 14, 2005 | 12:41 PM
Niall.b's Avatar
Niall.b
dont think they have any spring or shakeproof washers on as standard so they can vibrate loose. best stick a set of locknuts on it to be sure. have seen the studs removed & allen head bolts fitted. looks much neater too
Ginge !'s Avatar
Ginge !
just finding my feet
you havent snapped the studs though have ya
Old May 14, 2005 | 12:43 PM
boost mad's Avatar
boost mad
just noticed that she said inlet im such an idiot
Old May 14, 2005 | 12:44 PM
Niall.b's Avatar
Niall.b
made me go back to the top of the thread to check myself
Old May 14, 2005 | 12:45 PM
RSKim's Avatar
RSKim
Mrs Frog - dunno left the fella to sort it our pmsl
Tony - Wasn't me who did then tightening and what you mena the WAY I drive
b19bal - no aint snapped the studs
Niall - if they come loose again we were gonna change the bolts, it just a bit scarey that they came loose
Old May 14, 2005 | 12:46 PM
Ginge !'s Avatar
Ginge !
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
fuzzy
Aug 9, 2015 09:43 AM
tankybaby66
Aug 9, 2015 07:13 AM
