frst problem
Old Apr 29, 2005 | 06:12 PM
staffsm's Avatar
staffsm
Default frst problem
hello all
having troubles with my fiesta turbo,when i put my foot to the floor and try to rev it,it wont rev up! but if i press the accelerator very slowly it will rev?? also it is an intermitant fault,seems to be worse when its been running for ten minutes or so....any help on this would be greatly appreciated.any 1 any ideas please??
thanks
paul
Old Apr 30, 2005 | 05:28 PM
staffsm's Avatar
staffsm
no body got any ideas?????????
Old May 3, 2005 | 09:32 PM
staffsm's Avatar
staffsm
hmmmmm
Old May 3, 2005 | 09:52 PM
Šhatter Box's Avatar
Šhatter Box
when did u last have this set up? mite be a sticky cabel??
Old May 4, 2005 | 01:05 AM
Sellek's Avatar
Sellek
Could be the throttle position sensor mate.
Old May 4, 2005 | 05:53 PM
jrs's Avatar
jrs
if it is the throttle position senor unplug it. If it still play's up it's not that sensor
Old May 4, 2005 | 06:12 PM
staffsm's Avatar
staffsm
tried unpluging tps but still the same..i havnt had the car set up at all (i havnt had it long)
Old May 7, 2005 | 08:55 PM
white cab's Avatar
white cab
is it miss firing?
if so is the head gasket gone?
might have an air leak?
coolant sensor faulty?
charge air sensor?
crank sensor?
cam sensor?
connectors on the wrong plug?
just check these type of things on the car if you are wanting to do it on the cheap its just trial and error replacing engine sensors im afraid.
Old May 7, 2005 | 08:57 PM
white cab's Avatar
white cab
or even plugs, leads, coil pack wiring?
Old May 8, 2005 | 11:00 PM
staffsm's Avatar
staffsm
no it aint missfiring..its like it aint gettin enough fuel,its fine when its first started but then plays up after 10 mins or so...gona try a few sensors...anybody think it could be fuel pump??
Old May 9, 2005 | 07:15 PM
Matt_rS's Avatar
Matt_rS
I had the same thing on a later festa which turned out to be the timing was out!
First thing i would change would be coolant temp sensor(cheap an easy to do)
Next i would try dropping the exhaust could possibly be blocked i have come across this before with similar symptons!then i would check the timing.i wouldnt think it s the fuel pump coz they usually just give up an you wont get any fuel up,these are just my sugestions from my expierinces but id always start with the cheeper options first!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
