starting Problem on Esc Cos
Old Apr 29, 2005 | 03:39 PM
Turbo Chris's Avatar
Turbo Chris
Default starting Problem on Esc Cos
Hi,
I have an Escort Cos (large turbo)
Problem is i broke down yesterday and it wont fire up again
I was just driving,i pulled into a petrol station,filled up and when i went to start it it was just turning over but no final spark to make it run
Has anyone got any idea what i could check
Cheers,
Chris.
Old Apr 29, 2005 | 04:09 PM
matts1's Avatar
matts1
Does it have an imobiliser, could be playing up, this would let it turn but not let it start on some so they just turn over.
Not sure if they work by stopping fuel or spark though
Old Apr 29, 2005 | 09:07 PM
Dave Henshall's Avatar
Dave Henshall
when you go to click 2 (the one brfore cranking) on the ignition, do you hear the fuel pump run and the idle valve click? if you go back to 0 then back to click 2, does it do it?
could be the engine running relay failed in the fusebox or come loose, a failed imobilser, or coroded multiplugs, this is what happened 4 times with mine - after doin each of the above and it doin it again, it was " this " close to being set fire to cost me a few hundred quid in new bits beofer i found it was the multiplug wiring under the bonnet near the ignition coil
Old May 26, 2005 | 09:46 PM
Turbo Chris
still no joy
It has 2 immobilisers, cat 1 & Vecta cat 2
Yes you here the Idle valve click everytime
The Fuel pump goes on the 1st go at turning the key but doesnt prime through everytime
Ive cleaned the crank sensor
Replaced the:
phase Sensor
Ignition Module
coil
What colour and which relay is the engine running relay?
Anyone no a good auto spark in the North West around Liverpool?
Cheers,
Chris.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
Tinshaw
Aug 4, 2015 09:16 PM
