help 4x4 not starting
Old May 22, 2005 | 04:06 PM
ian_cars's Avatar
ian_cars
Default help 4x4 not starting
Hi please can somebody help me.(4x4 saph)
I Fitted new samco coolant hoses on my car and when taking one of the top hoses off water spilled over the dizzy cap so when i came to start it no 4 would not fire and the car started on three cylinders but once i used wd40 on the dizzy cap and put it back together the car won't even fire.
I have had a mechanic look at it and he suggested the spark was not strong enough from the coil, so we replaced the coil, rotor arm & dizzy cap for genuine ford items and the car still wont start,
There is a spark at all four plugs and they all get wet from the fuel, also i have checked all plugs and leads and cant find anything wrong.
I would be very greatfull if someone could give me some advise to sorting my problem out Thanks.
Old May 22, 2005 | 06:27 PM
Dave Henshall's Avatar
Dave Henshall
might be an obvious one, but have you got them back on in the correct order....?
Old May 22, 2005 | 06:42 PM
ian_cars's Avatar
ian_cars
yes checked this a few times thanks anyway
Old May 26, 2005 | 09:35 PM
Turbo Chris's Avatar
Turbo Chris
i've got the exact same problem with my esc cos
Upto now ive changed the phase sensor, coil, ignition module, cleaned the crank sensor aswell
come on people we are getting sad now
Chris.
Old May 26, 2005 | 10:39 PM
ian_cars's Avatar
ian_cars
ive now sorted mine i swapped the ignition amplifier with one on another cossie and it started no problems, good luck!
FlashRS
Sep 14, 2015 12:36 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Anutternutter
Aug 21, 2015 06:07 PM
Tinshaw
Aug 4, 2015 09:16 PM
Old ford
Jul 31, 2015 06:50 AM
