crank pulley quick ????
Old Apr 22, 2005 | 05:30 PM
tosh's Avatar
tosh
Default crank pulley quick ????
Help! I've been trying to get the crank pulley bolt undone, just two questions:
1, which way to undo, been trying to do it anticlock
2, put hand brake on, engaged 1st gear, put brake pedal lock on but the pulley still turns, can this do any damage to force the engine in the wrong direction.
Thanks
Old Apr 22, 2005 | 06:17 PM
ajjames's Avatar
ajjames
i used a strong bar on mine and rested it on an axle stand then cranked the engine over it undid no problem
Old Apr 22, 2005 | 06:18 PM
ajjames's Avatar
ajjames
Old Apr 22, 2005 | 06:42 PM
tosh's Avatar
tosh
that sounds a bit severe mate, but i see what you are saying I might try it if all else fails.
Old Apr 22, 2005 | 06:46 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I tried a long bar with car in gear, handbrake and brakes on to no avail.
Then I used an impact driver, the bolt came out while the head was off and the car out of gear...
See if you can borrow one, you'll be greatful.
Only problem is, you need to take the rad out to get the driver in there.
Old Apr 22, 2005 | 07:35 PM
rsnissan's Avatar
rsnissan
remove the starter and wedge a screwdriver in one of the teeth on the flywheel
Old Apr 22, 2005 | 07:39 PM
tosh's Avatar
tosh
I've already taken the rad out because i'm also curing an oil leak on the auxiliary shaft oil seal, so decided to do the cam belt as well.
can any one still answer the question about forcing the pulley's the wrong way while trying to undo the bolt, because I don know if you can damage anything by winding the engine backwards.
Old Apr 22, 2005 | 08:03 PM
rsnissan's Avatar
rsnissan
i dont think you can do any damage really as its all in phase anyway
Old Apr 22, 2005 | 08:25 PM
tosh's Avatar
tosh
Now you have surpassed my intelligence "as its all in phase anyway"
BUT CHEERS FOR THE REPLYS SO FAR.
IDIOT PROOF ANSWERS FROM NOW ON PLEASE
Old Apr 22, 2005 | 09:41 PM
rsnissan's Avatar
rsnissan
well so long as timing is ok as in the belt is still on i dont think it would matter as your just turning it by hand anyway. but thats just my opinion
Old Apr 23, 2005 | 11:31 AM
killerscum01's Avatar
killerscum01
Hi
Its a standard right hand thread.
And you should put it in 5th gear
Old Apr 23, 2005 | 06:45 PM
john_p_b's Avatar
john_p_b
you won't do any damage turning the engine backwards especialy seeing as you are changing the timing belt anyway
Old Apr 24, 2005 | 11:22 PM
tosh's Avatar
tosh
Cheers everyone for your replys, as ubove I wedged a thin 2" bilster in the starter motor recess I might even make up a home made tool to do this properly because it works so well, it locks up the crank shaft pulley completely so you can put some proper force on that bastard bolt.
Mind you it still needed a 18" braker bar with a 3 foot pole extension on the end of it to free the foooker.
Old Apr 27, 2005 | 09:44 AM
rsnissan's Avatar
rsnissan
Glad you got it sorted in the end
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
