Sierra Cosworth Sapphire 4x4 Turbo - Small vibration on the steering whell
Aug 20, 2024 | 11:16 AM
Hello All.
When I break I get a vibration on the steering wheel and steering column.
As I was told, this is a comum thing on these cars to happen, I have checked the front rotors and they seem fine, could it be the steering bushes ?
Jorge
Aug 20, 2024 | 02:06 PM
Also check your TCA’s track control arms, these cause vibration through the steering wheel if they are in poor condition
Aug 20, 2024 | 07:09 PM
Quote:
Originally Posted by
charlie luciano
Also check your TCAs track control arms, these cause vibration through the steering wheel if they are in poor condition
Thanks 😊
Will check that later on the weekend, and update the result
Aug 20, 2024 | 08:28 PM
make sure you dont have a sticky caliper ,check your rubber brake bipes are in good condition and havent collapsed inwards
Aug 20, 2024 | 08:45 PM
james kiely
thanks for the update.
The car brakes strong and very well , I only have that annoying vibration on the steering wheel
will try to sort it out during the weekend 🙌
Aug 21, 2024 | 02:52 PM
even if it brakes well ,it doesnt mean the caliper is releasing properly jorge and can cause a vibration in the steering wheel
Aug 21, 2024 | 06:52 PM
james kiely
Iam getting more inclined to this possibility, because the car is used only a few times a year, so the caliper can indeed getting not to release properly, because of lack of usage.
I had similar problems with my other vintage cars
.the solution is to use the car for some days or take it for a long ride on the country side, outside the motorway, to see if the problem disappears 👌
thanks for the help 🙌
Best
Aug 23, 2024 | 09:10 AM
Normally the TCA to ARB bushes are very weak and can cause vibrations. Poly bushes should solve that.
Jack and the Beanstalk
Jul 26, 2016 05:29 PM
cossynut2
31
Jul 28, 2015 05:24 PM
peteh
Jul 1, 2011 01:06 PM
bankyg60
Dec 19, 2004 08:56 PM
