Ford Focus 2.0 TDCI 2010 No Start. Only Quick Start
Hi everyone,
I'm stuck at a brick wall and I wanted to know if anyone could point me in the right direction. I have a ford focus 2.0 tdci that I recently bought as a no starter. The car only starts on quick start, once quick start is sprayed into the intake the car will run. I've driven it around and left it idling for some time. When i turn the ignition off, it cranks but does not start until I use quick start. I'm not a machinic but I've learnt a bit over the years trying to fix my own problems, any help/guidance will be appreciated.
These are the codes i get from forscan.
===PCM DTC P0406-F1===
Code: P0406 - EGR Sensor A Circuit High
Additional Fault Symptom (:01):
- Signal is Above Maximum Threshold
Module: Powertrain Control Module
Diagnostic Trouble Code details
This DTC may be caused by :
Electrical connectors not fully engaged
Wiring Harness Short to Battery or Short to Ground
Check for continuity shorts to ground and battery positive.
Inspect connectors for signs of damage, water ingress, corrosion, etc.
Faulty or damaged PCM.
===END PCM DTC P0406-F1===
===PCM DTC P0088-61===
Code: P0088 - Fuel Pressure Control Valve Circuit Low
Status (-60):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Fuel Pressure Control Valve Circuit Malfunction
Leaking injector
Fuel leakage
Insufficient fuel.
===END PCM DTC P0088-61===
===PCM DTC P1335-62===
Code: P1335 - EGR Position Sensor Minimum Stop Performance
Additional Fault Symptom (:02):
- Signal is Below Minimum Threshold
Status (-60):
EGR Position Sensor B Minimum/Maximum Stop Performance
Short circuit in wiring or component.
Check for a stuck or sticking EGR actuator.
EGR valve assembly
If the EGR actuator has been renewed initiate the EGR component parameter reset.
===END PCM DTC P1335-62===
===PCM DTC P2141-64===
Code: P2141 - Exhaust Gas Recirculation Throttle Control Circuit Low
Additional Fault Symptom (:04):
- There is no change in the signal
Status (-60):
Air Shut Off Throttle
throttle valve stuck
EVR circuit fault
Wiring Harness Open Circuit
Check the following:
Vacuum supply leakage / restriction
Disconnect the vacuum pipe from the component and, using a suitable length of vacuum hose, connect a hand-held vacuum pump to the component.
Steadily apply a vacuum while observing the operation of the linkage. Make sure that it moves smoothly to the limit of its travel and that it returns to its original position when the vacuum is released. If the linkage does not move or fails to operate over its entire range, suspect the component.
===END PCM DTC P2141-64===
===PCM DTC P2263-E1===
Code: P2263 - Turbocharger/Supercharger Boost System Performance
Status (-E0):
- Malfunction Indicator Lamp is On for this DTC
Blocked vacuum hoses
Possible causes are:
Check for vacuum leaks.
Check the vacuum hose routing; if you are in doubt, refer to the appropriate service literature.
===END PCM DTC P2263-E1===
===PCM DTC P0113-61===
Code: P0113 - IAT Sensor Circuit High Input
Status (-60):
Damaged or contaminated connector
IAT sensor / wiring
Signal circuit shorted to VBATT.
Short to VREF.
Incorrect VREF.
Sensor Previously disconnected.
Check for MAF related DTCs.
For further diagnostic information refer to the appropriate section of eTIS.
===END PCM DTC P0113-61===
===PCM DTC P0101-E1===
Code: P0101 - MAF circuit range/performance problem
Status (-E0):
Open ground between sensor and PCM.
Incorrect or low voltage from VPWR.
Faulty MAF sensor
Intake system leaks
Broken or leak in inlet duct from MAF sensor.
Loose clamps on inlet duct.
===END PCM DTC P0101-E1===
===PCM DTC P0002-61===
Code: P0002 - Fuel Metering Control Valve Circuit Malfunction
Status (-60):
Air in the fuel system
Blocked or contaminated fuel filter.
Blocked kinked or crushed fuel supply lines
External fuel system leaks
Fuel Metering Control Valve Open Circuit
Fuel Metering Control Valve Circuit High
Fuel Metering Control Valve Short To Ground
Check the PCM for the latest calibration.
Experience has shown that the symptoms of this fault are:
RFM
Driveability Concerns
No Start/Hard Start or Engine Stalls
Low fuel pressure.
===END PCM DTC P0002-61===
===PCM DTC P0089-61===
Code: P0089 - Fuel Pressure Control Valve
Status (-60):
Leaking fuel rail
Pressure sensor signal
Leaking injector
Insufficient fuel.
FIP malfunction
Poor start or no start
Low fuel pressure.
High fuel pressure.
===END PCM DTC P0089-61===
===OBDII DTC P0406-C===
Status (-43):
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII DTC P0406-C===
===OBDII DTC P2263-C===
Status (-43):
===END OBDII DTC P2263-C===
===ABS DTC B1318-A0===
Code: B1318 - The battery voltage level is too low.
Status (-A0):
- Previously Set DTC - Not Present at Time of Request
Module: Antilock braking system
Battery Voltage Low
Check fuses.
Power supply to fuse
Discharged or faulty battery.
Check the condition of the battery.
Check the battery charging system.
Check the connector for damage or contamination.
Check the connectors and wiring harness for damage or contamination.
Check the wiring and the appropriate fuse.
High resistance in wiring
Additional Information
The ABS lamp should be illuminated.
The ESP lamp should be illuminated.
There will be an ESP malfunction warning displayed on the driver information text panel.
===END ABS DTC B1318-A0===
===ABS DTC C1145-E0===
Code: C1145 - Right Front Wheel Speed Sensor Input Circuit Failure
Status (-E0):
Sensor or module replacement must only be carried out after the following checks are performed.
Check for an open circuit in the wiring harness.
The sensor was previously disconnected, check the sensor connector.
Check for a short circuit to the ground or battery.
Check that the supply voltage to the ECU is approximately 12 volts with the ignition in position II.
Disconnect the sensor. Check that the supply voltage at the sensor connector wiring harness is approximately 12 volts, with the ignition in position II.
If there is no voltage the possible fault is the main wiring harness, connector or ECU module.
Sensor replacement must only be carried out after the following checks are performed.
After clearing the DTC, the vehicle must be driven above 20kph (13 mph), during normal driving conditions, to extinguish the ABS lamp.
===END ABS DTC C1145-E0===
===ABS DTC C1155-E0===
Code: C1155 - Left Front Wheel Speed Sensor Input Circuit Failure
Status (-E0):
===END ABS DTC C1155-E0===
===EPS DTC U261B-20===
Code: U261B - Improper Program Termination
Status (-20):
Module: Electronic-Controlled Power Steering
===END EPS DTC U261B-20===
===IC DTC None===
Successful DTC reading, no error codes found
Module: Instrument Cluster
===END IC DTC None===
===PDM DTC B2035-60===
Code: B2035 - Side turn repeater indicator short to ground.
Status (-60):
Module: Passengers Door Control Unit
Check side turn indicator lamp.
Carefully check the wiring between the Door Control unit and side turn indicator assembly.
===END PDM DTC B2035-60===
===PDM DTC B2218-60===
Code: B2218 - Central Lock Line Short Circuit to Ground.
Status (-60):
===END PDM DTC B2218-60===
===DFDM DTC None===
Module: Driver Door Control Unit
===END DFDM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===GEM DTC None===
Module: Generic Electronic Module
===END GEM DTC None===
Status (-60):
Leaking injector
Fuel leakage
Insufficient fuel.
Status (-60):
EGR valve assembly
Status (-60):
EVR circuit fault
Status (-E0):
Status (-60):
IAT sensor / wiring
Short to VREF.
Incorrect VREF.
Status (-E0):
Faulty MAF sensor
Intake system leaks
Status (-60):
RFM
Low fuel pressure.
Status (-60):
Leaking fuel rail
Leaking injector
Insufficient fuel.
FIP malfunction
Low fuel pressure.
High fuel pressure.
Status (-43):
Status (-43):
Status (-A0):
Battery Voltage Low
Check fuses.
Status (-E0):
Status (-E0):
Status (-20):
===IC DTC None===
Status (-60):
Status (-60):
===DFDM DTC None===
===RCM DTC None===
===ACM DTC None===
===GEM DTC None===
hynes67
Apr 3, 2011 03:57 PM
nickywarwick
Jan 18, 2010 07:32 PM
