any vauxhall specilist on the fourm.. corsa 1.3 cdti limp mode help p0108 fault code
as pete title
the gf's 2005 corsa goes into limp mode. we broke down in manchester a few weeks ago got AA out as car would not go over 2.5k no boost they found fault code p0108
been told ist either.....
egr valve
map sensor
air flow sensor not that as have taken it off and still goes into limp mode
turbo boost pipe
turbo unit
looked on other fourms but no luck hence im posting it on here
need to know what this code means as im fooked if im buying bit by bit to find out its not them
thanks pete
egr valve
map sensor
turbo boost pipe
turbo unit
thanks pete
found out it was the map sensor. unpluged it and it not gone into limp mode since. thanks pete
mk3ste
17-10-2021 10:09 AM
Si B
12-09-2015 06:49 AM
