Escort 1996 Blower Problem
Old Dec 19, 2023 | 11:28 AM
Lynrobbo's Avatar
Lynrobbo
Smile Escort 1996 Blower Problem
Hi, First time on here so perhaps someone may be able to help.
Ford Escort 1996 1800 Ghia.
Problem
Heater Blower inside car stopped working.
No power from either end of fuse 20 (25amp) on front of box. (Ignition on).
put power to output fuse and it works.
Put power to switch in car and it works.
A live wire should come from fuse to the switch (which is dead )
Worked on/off after test several times but then stopped again. Haynes manual says fuse goes to IGNITION RELAY. Possibly faulty.
Where is it ?? On the fuse board or elsewhere ?
Also, quick fix
Replaced front windscreen does not have a heated screen so switch for heated windscreen redundant. Is it ok to take power feed from heated front screen switch to the Blower switch which would fix the problem if i cant replace Ignition relay.
Appreciate any help/suggestions. Thanks
Old Dec 19, 2023 | 03:47 PM
GVK.'s Avatar
GVK.
Sounds like classic fuse box failure
Old Dec 21, 2023 | 04:00 AM
MaybellBrown's Avatar
MaybellBrown
I sometimes face problems with my blower and electrical devices, but they are usually minor and easily solved.
Spoiler
Old Dec 21, 2023 | 10:17 AM
Lynrobbo's Avatar
Lynrobbo
I know but i prefer help opposed to sympathy !! Thanks anyway.
Old Dec 21, 2023 | 01:45 PM
haz87's Avatar
haz87
Agree with GVK. Fusebox on its way out. Thankfully easily swappable, just try get the same code, or worst case from a higher spec model than what you have
Old Dec 21, 2023 | 06:08 PM
Lynrobbo's Avatar
Lynrobbo
Thanks for that. My previous 1996 Escort 1600 GL went to scrap cos I couldn’t replace the fuse board. Couldn’t find one so i am not optimistic about getting a replacement for 1996 1800 Ghia 5 years on from the 1600 GL.
Old Dec 23, 2023 | 12:18 PM
ray barker's Avatar
ray barker
just put a small fuse box next to the main one you can get ones that hold as little as half a dozen fuses and wire it direct to your blower switch/circuit. if you dont want it to be seen hide it inside the car. if you cant do this yourself an auto electrician wouldnt charge much to do this. the chap i use quoted me five hundred to change my saff fuse box . i also have a smaller fuse box as well hidden away for the rad fan headlights and a few other things
Old Dec 23, 2023 | 01:54 PM
james kiely's Avatar
james kiely
more than likely just a dry solder joint on the back of the fuse box circuit board Just remove and resolder the joints again,or as Ray said put another separate fuse in
ChrisJD
Fiesta ST
Mar 5, 2012 01:06 PM
delbe
Aug 29, 2011 12:55 AM
hullguy1974
Nov 20, 2010 05:14 PM
martinmace
May 5, 2006 09:36 PM
220TC
Jan 6, 2005 04:06 PM
