what next??
Old 04-05-2006 | 10:07 PM
martinmace's Avatar
martinmace
Default what next??
well ive been fucking around with the cossie and i cannot get power to the fan temp switch put new relay, fuses, etc and no joy really fucked off now as i am wanting to start using it but wont until this is sorted but dont know what to do next any suggestions??
Old 04-05-2006 | 10:31 PM
Tangodeltasierra3's Avatar
Tangodeltasierra3
My fuse was all melted in the fuse box so i had to have a seperate fuse wired under my dash - must be summat simple i imagine!
Old 05-05-2006 | 08:57 AM
foreigneRS's Avatar
foreigneRS
Testing the future
don't understand what you're trying to do?
the fan switch does not get 'power' - it just switches one side of it to earth to earth the coil for the relay that gives power to the fans
to test if the switch is faulty, just short the 2 connections and the fans should start. if they don't it's a fault elsewhere - probably the fuse box
Old 05-05-2006 | 10:34 AM
cossie cris's Avatar
cossie cris
Run an inline fuse and new wiring, with a new switch for the fan itself and have it running all the time when your driving, and switch it off when your parked etc...?
Old 05-05-2006 | 08:59 PM
martinmace's Avatar
martinmace
shorting the wires is the first thing i did thats how i know they are fucked anyway i bought a 4 pin relay today and rewired it from scratch and now they work as normal with the added extra of staying on even when you switch off the engine if the fans are still running unlike the standard set up of cutting out with the ignition of course my boss did me a little wiring diagram on how to do it
Old 05-05-2006 | 10:36 PM
CosKev3's Avatar
CosKev3
Glad you sorted it
But standard set up should run on after the ignition has been switched off if temps are high enough for switch to work,well both my saphs have done this anyway
