Mfi to efi fuel lines
Old Aug 21, 2023 | 05:59 AM
BlakeMoyle's Avatar
BlakeMoyle
Wish I had more time!
10 Year Member
Default Mfi to efi fuel lines
Morning everyone,
I know it’s probably been covered a million times but I can’t find it anywhere, I’m in the process of converting but not sure what I need to use fuel side in regards to old accumulator etc and the frst fuel rail has the end on the pressure regulator and then a screw on type at the other end, some detailed advice and maybe some pics would help me out a lot so i can get this all buttoned up. Thanks in advance
Blake
Old Aug 21, 2023 | 12:05 PM
nigel b's Avatar
nigel b
tank to pump
pump to start of fuel line
end of fuel line to filter
filter to fuel rail
other end of fuel rail back to fuel return pipe
other end of return pipe back to tank
ideally you want a pre filter on the pump and a post filter
Old Aug 21, 2023 | 07:53 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Originally Posted by nigel b
tank to pump
filter to fuel rail
hi mate thanks for the reply that helps a lot, I’m assuming filter to fuel rail is to the regulator then the other threaded end is the return?
Old Aug 22, 2023 | 07:51 PM
boost monster's Avatar
boost monster
I moved my fuel filter to a bracket mounted on the steering rack so I could get petrol running down my arm every time I have to change it🤣🤣
It was to clean up the bay and hose routing. 😁
Old Aug 22, 2023 | 09:41 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
🤣🤣 I do like the smell of petrol not sure about using it as a cologne though! I was thinking of trying to mount somewhere inconspicuous I’ll have to look at some options, have you got a picture of yours?
Old Aug 23, 2023 | 12:30 PM
nigel b's Avatar
nigel b
i have my pump and both filters at the back of the car
Old Aug 25, 2023 | 04:48 PM
boost monster
I cut the hard lines at a suitable place where the hose could connect too and fitted a compression to an6 fitting.
I didn’t like the filter on the inner wing with the hoses looping around the inlet.
Old Aug 26, 2023 | 08:30 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
that looks like a nice and tidy job, do you know what fittings you bought to go onto the filter? I may do the same looks a lot cleaner than going across the wing
thanks
Blake
Old Aug 26, 2023 | 05:23 PM
boost monster
I think they are M14 & M12 to an6 from torques.
mentalasanything
Mar 19, 2010 10:02 PM
PaulT
Feb 3, 2010 12:54 PM
Karlos G
Aug 3, 2009 08:57 PM
stevenebm
May 3, 2009 09:40 AM
shaun
Apr 6, 2008 08:30 AM
