rattleing erst
Old Apr 16, 2005 | 12:26 PM
sy-rst's Avatar
sy-rst
Default rattleing erst
my escort rs turbo has started a realy bad rattle.it sounds like its from the top end.i dont think its the lifters.it was a quiet engine b 4.also it seams 2 have a lot of pressure under the oil cap coz when u remove the cap its chuffing out exhaust fumes.there is no smoke from the exhaust so i think the rings r ok.any one got any idears.
Old Apr 16, 2005 | 05:05 PM
DmcL's Avatar
DmcL
leaky valve seats maybe? nothing ive ever come across in any of my cars before so i can only guess..
Old Apr 16, 2005 | 07:26 PM
Moonie's Avatar
Moonie
Cant see how exhaust fumes can be coming out of the oil filler cap
The fumes you see when the cap is removed are the combustion gases that have passed the rings and gone into the sump (blow-by gases). If it is breating very heavilly then the rings are knackered and maybe the pistons. The rattle you are hearing mite be piston slap.
Old Apr 16, 2005 | 07:48 PM
steviep's Avatar
steviep
Dip the clutch and see if it stops, layshaft bearing wear is very common with these gearboxes and can easily be mistaken for an engine rattle.
Old Apr 18, 2005 | 09:16 AM
sy-rst's Avatar
sy-rst
the rattle is realy bad when i first start the car then dies down slightly.if it was the rings then wouldnt it smoke loads through the exhaust.
Mc5506
Oct 5, 2015 09:57 PM
beller
Sep 21, 2015 04:13 AM
Fudgey
Sep 17, 2015 01:06 PM
Bailes1992
Sep 3, 2015 02:17 PM
Ellsa
Aug 9, 2015 07:03 PM
