ECU, clocks etc swapping
I have a 2010 ford focus st mk2 with a very annoying non start problem.
It started off being intermittent and its now become perminent.
We have had the ecu tested, tried different clocks and bdm.
I have another vehicle same as and factory spec, what is needed to swap across so it would start and run?
So far we have swapped, bdm, clocks, ecu and module for remotes - comes up steering lock on and no ignition.
Any help appritiated.
thanks
thanks
