Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Cam Shaft Seals Help Please!
Old Aug 10, 2021 | 06:44 AM
tigre76's Avatar
tigre76
Default Cam Shaft Seals Help Please!
A couple of weeks ago I replaced the cam belt on my MK1 16V Focus 02 plate and I decided to replace the cam shaft seals on the cambelt end.
The original seals were level with the side of the head however the new ones I tapped in as far as they would go and I'm not sure if I should have done that, will it be okay as I did notice looking at picture of another cylinder head there's a small oil hole located just behind the camshaft seals, will it now be blocking it or not?
gaz s1
Mar 16, 2010 09:27 PM
cossieprob
May 7, 2009 09:59 AM
adam.d
Feb 16, 2009 07:53 PM
LukeT
Jan 13, 2007 07:02 PM
GraphiteGray
Sep 15, 2004 03:57 PM
