Forged?
Old Mar 15, 2021 | 08:03 PM
RSBryden's Avatar
RSBryden
10 Year Member
Default Forged?
Right guys, long story short, I bought the st that has had forged pistons n rods, the car has receipts for all the work done by devil developments.
ive spoken to them to confirm and they have updated there hole system and lost all history. so can’t pull up any history of any works carried out on any car up until the start of this year, which is fair enough, he said if it’s got receipts, it’s pretty much been done mate,
ive been under the car and it has a 2.5” cat back exhaust, was sold to me stating is a full 3” system. From the dealer.
the car had a standard cat on it, the dealer then sent me the decat for the car through a courier as he needed cat on it for mot and didn’t chNge it over again.
im wondering if the previous owner has switched out the engine for a standard block and sold the car with the receipts of the work which had been done on the built engine. Tomorow I have a mechanic coming around to look down the spark plug gaps with a endoscope to see if the piston are actually forged.
what will I be looking for to confirm if my theory is correct,
I might be paranoid but I need to know as it’s doing my head in.... thanks in advance
Old Mar 15, 2021 | 09:27 PM
Rsmat's Avatar
Rsmat
You would be better whipping the sump off rather than going down the bore with the scope mate ..you'll see the rods and pistons better.
Old Mar 15, 2021 | 10:56 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
even easier would be to remove the block breather.. 3 8mm bolts and you should be able to see the rods
Old Mar 16, 2021 | 05:26 AM
RSBryden's Avatar
RSBryden
10 Year Member
We’re is the block breather mate?
if I can’t see much from the bore then I will drain the oil n take sump off pal..
Old Mar 16, 2021 | 09:57 AM
Rsmat's Avatar
Rsmat
I just thought the sump will show you both rods and pistons, the breather will show you the rods and the bore scope the crowns of the pistons that maybe black and hard to tell .. which ever way , good luck 👍
Old Mar 16, 2021 | 12:47 PM
XRT_si's Avatar
XRT_si
Check the engine number if you can - although that's quite tricky on a Mk2 Focus without a ramp.
Looking down the bore can be hard to work out if it has forged pistons, as something like a Wiseco looks a lot like a standard Mk2 RS piston from the top.
Old Mar 16, 2021 | 06:43 PM
RSBryden's Avatar
RSBryden
10 Year Member
Old Mar 16, 2021 | 06:44 PM
RSBryden's Avatar
RSBryden
10 Year Member
Yeh I think these are ok, they look like weisco and the receipt says they are 😁 happy about that lads I tell ya 😎
Old Mar 16, 2021 | 06:56 PM
RSBryden's Avatar
RSBryden
10 Year Member
Thanks for all your help guys and input! A piece of mind now.... she can go big power and take a good hiding and love it lol
Old Mar 16, 2021 | 07:49 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Your pick a full system up second hand on Facebook. I got a 3inch down pipe. A 200 cell sport cat and full mongoose system cheap.
Old Mar 19, 2021 | 09:23 AM
XRT_si's Avatar
XRT_si
I wouldn't say they are Wiseco pistons but don't look standard either so should be good.
Old Mar 19, 2021 | 10:27 AM
RSBryden's Avatar
RSBryden
10 Year Member
I’m glad mate , had a feeling n couldn’t relax until I checked.I bought a endoscope off eBay mate that attaches to my phone Ł15 .. great bit of kit I must admit
andy130
May 25, 2015 12:00 PM
BLU
Jan 19, 2014 08:04 AM
Marcyg
30
Aug 28, 2013 06:55 AM
xrmalin
Nov 17, 2008 09:27 PM
B11GNS
11
Feb 25, 2007 06:37 PM
