Turbo blown on 2008 1.8D
No more Alfa's for me...
Hi everyone,
The turbo blew on my 2008 Focus 1.8D with just over 100k on the clock.
Garage plugged ECU in and it showed two possible faults; boost pressure sensor or turbo charger.
I replaced the sensor with a good Bosch one with the exact same part numbers and it’s the same; total loss of power.
Took it back to the garage and they said it’s screwed and needs a new turbo, as it’s blown clean off the mountings or something!
Quoted me £1,400 to replace turbo, flush the system, replace the sump, oil flow test and a few other items (filters, hoses, pumps...)!
The car’s only worth about £1,200 if it was in good condition.
This seems STEEP don’t you think?!
The cost of the turbo is £700 alone, then the rest of the money is for the other parts and labour.
I don’t know what to do as I’m not earning much at the moment as I’m self employed and covid has badly affected my business.
What are your thoughts please?
A) Scrap it for £250
B) Sell it for spares / repair for £500
C) Get a one man band mechanic to fix it for hopefully a lot less
D) Other options???
I’ve got another vehicle, my Campervan, which I can use but am trying to keep the miles down on that and it’s also quite big for parking easily in towns etc.
Pretty gutted. I’ve looked after this car for many years and planned to keep it until it died. Looks like it just has!
I know you can get new turbos cheaper or recon ones or even used ones but the garage refused to fit parts I supply.
Thanks in advance...
D) Other options???
So it's blown clean off the mountings....yet they just plugged something in and read some meaningless codes and did no proper diagnosis ?
Go find a competent mechanic instead of those clowns. Or just scrap it.
But used turbos for such a vehicle seem to be around £50-100 on ebay. £700 does seem bollox no matter what way it is dressed up.
They did stick it on a ramp and inspect it and that’s what they said they found, but the cost for the whole job sounds ludicrous!
I’ll see if I can get a second opinion and cost, or maybe a few and decide what to do.
I’m not working and not able to claim any benefits so money is beyond tight!
Cheers👍🏻
mustang 390
17
Feb 11, 2010 03:38 PM
morto
45
Feb 19, 2009 05:04 PM
