Steering Column
Old Dec 20, 2020 | 02:12 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Default Steering Column
Can anyone give me any idea how much of a job is it to replace the internal shaft on the column? the bit that the wheel nut screws too?
​​​​​​Reason for changing is some muppet has cross threaded it at some time making it unable to tighten up as it should.
Old Dec 20, 2020 | 04:26 PM
gus's Avatar
gus
How bad is it?
coult you get a thread repair on it.
done this on a wheel stud and worked a treat
Old Dec 20, 2020 | 04:53 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Originally Posted by gus
How bad is it?
don't think so 1 side completely flat no thread left. I got spare shaft at home.
Old Dec 21, 2020 | 12:22 PM
nigel b's Avatar
nigel b
unbolt the steering column from the rack
remove the shroud and switches etc..
undo the 2 bolts on the lower steering column
undo the 2 upper bolts on the steering column
Old Dec 21, 2020 | 07:34 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Cheers will have a look at doing over xmas holiday i think.
Old Jan 5, 2021 | 12:56 PM
Bigkevg's Avatar
Bigkevg
5 Year Member
have you tried a dye, put new thread on it
Old Jan 6, 2021 | 09:30 AM
Rogeyboy's Avatar
Rogeyboy
I would try and re-thread.
stuart1507
Ford KA
Apr 25, 2015 08:21 AM
marc_gti
Apr 27, 2013 07:56 AM
Antti O
May 24, 2009 01:33 PM
JimmyBoy
Sep 29, 2007 04:08 PM
terranova
Ford Escort RS Cosworth
Aug 12, 2006 06:38 PM
