Heavy steering
Old Apr 24, 2013 | 06:36 PM
marc_gti's Avatar
marc_gti
Default Heavy steering
hi all
ive replaced my top mount bearings, lower arms, steering rack and my steering is still pretty heavy
can anyone point me in the direction of what steps to follow
many thanks
Old Apr 24, 2013 | 07:04 PM
Louis_RST's Avatar
Louis_RST
Isnt there a bearing in the steering column?
Other than that maybe get the front wheel alignment checked?
Old Apr 24, 2013 | 07:05 PM
marc_gti's Avatar
marc_gti
alignment is checked mate
Old Apr 24, 2013 | 10:51 PM
chrisp4632's Avatar
chrisp4632
PassionFord Hobo
have you checked you steering joint that connect to you rack it might be seized
Old Apr 24, 2013 | 11:02 PM
botters's Avatar
botters
competant bodger
my steering was quite heavy on my rs turbo but it felt a lot lighter after fitting some toyo proxes but i would also check the uj as if thats siezed it will be heavy
Old Apr 25, 2013 | 06:19 AM
marc_gti's Avatar
marc_gti
can it be seized even if it still moves?
Old Apr 25, 2013 | 09:16 AM
haz87's Avatar
haz87
Most likely the crappy plastic sleeve in the steering column thats decided its had enough
http://www.ebay.co.uk/itm/Escort-Mk3...item257ca153da
Old Apr 25, 2013 | 11:47 AM
Rogeyboy's Avatar
Rogeyboy
As above... Changed this on afew mk4 escorts/orions and it makes the steering loads lighter again!
Old Apr 25, 2013 | 12:39 PM
marc_gti's Avatar
marc_gti
so is the kit thats listed above on ebay the kit to get?
Old Apr 25, 2013 | 01:53 PM
haz87's Avatar
haz87
Yes...
Old Apr 25, 2013 | 05:27 PM
rsmark86's Avatar
rsmark86
i had one with a worn diff and made mine very heavy
things to look into...
tyres
alignment
how low is it? ect
steering uj
coloum
have you tried jacking the car up and seeing if the steering spins freely in the air?
Old Apr 25, 2013 | 07:55 PM
marc_gti's Avatar
marc_gti
ive not jacked it up to check yet, could that make a difference? worn diff?
Old Apr 27, 2013 | 07:56 AM
rsmark86's Avatar
rsmark86
could be a whole host of things mate....
i will get them suspension bushes out later too mate
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
