2.0 Zetec Running Rich
Hello, would be really grateful for any ideas/help.
I have a 2.0 silver top Zetec in my mk3 fiesta which I put in myself.
I feel it’s running rich as the oil smells of fuel, it sometimes ‘pops’ from the exhaust and kangaroos on light throttle and when it’s warm it hunts on idle.
I have looked everywhere for air leaks, replaced the following sensors with new - air intake, coolant temp, lambda. I’m questioning the MAF but have no way of testing it, I’ve also swapped the TPS for another.
it pulls really well and revs lovely just do t want to do any damage caused by borewash!
Bill,
Bill,
Have you checked the rubber hose that goes onto the PCV (runs under the coil pack bracket)
Whats the set up of the valve cover breather at the back?
the breather at the back of the cam cover just has a small filter on it
So I have bought a new (Genuine) MAF to try. Question is can anyone tell me which pins do what on the MAF?
min using a DEEP ECU so I know pin 50 goes to the MAF but not sure which pin and also what the other pins are for.
There will be a 12v supply green or may be purple ? A chassis earth black ? A common ecu earth, brown ? The sensor wire white ? It’s a while since I did a pre pats.
