ecu relay clicking
Old Nov 27, 2020 | 09:59 AM
tommyrs's Avatar
tommyrs
Default ecu relay clicking
hello hope someone can help
the problem is when i turn the ignition on the fuel pump keeps running and the ecu relay just keeps clicking anyone had this problem before
strange thing is after alot of turning the key on and off the relay dose stay on and it starts and runs
my car ia an ra turbo s2 running cosworth mangement
Old Dec 12, 2020 | 08:42 PM
stevieturbo's Avatar
stevieturbo
C**t
Strange problems, are often a bad ground somewhere.
If the ecu was really going off....so should the fuel pump when the ecu is off.
Test for the relevant power and grounds etc at the relays, and check grounds elsewhere.
Fil
Jul 18, 2015 02:42 PM
rosie
Oct 2, 2010 10:15 AM
rog
May 22, 2009 10:34 AM
cossiescott
Dec 4, 2004 11:33 AM
mk5cos
Ford Escort RS Cosworth
27
Nov 13, 2004 06:47 PM
