Cooling fan always ON
Old Nov 21, 2020 | 12:07 PM
sevenup85's Avatar
sevenup85
Default Cooling fan always ON
Hi guys,
I noticed my fans are going on just after 5 minutes my car started, both fans are running low speed all the time.
I just got the car a few months ago and noticed temperature on the dashboard stays pretty low all the time, like the car never warms up, It is situated more or less at the quarter of the screen temperature, is it normal operating on the RS? sometimes cars are different, I thought it should be in the middle.
Anybody got a picture of sensor level on dashboard at normal temperature?
FYI: timing belt, hoses, thermostat and cooling liquid are new
Thanks for your answers
Cheers. Roland
Old Nov 21, 2020 | 04:30 PM
martysmartie's Avatar
martysmartie
The fans should not be on, possibly a faulty fan switch.
The Escos has a two speed fan system, I am not that familiar with it but will be fairly basic, probably a low speed and high speed relay.
The gauge sounds about right, mine sits near the bottom and at the most in the middle in hotter weather.
You really need an IR thermometer to accurately gauge the temperature.
Martin
Old Nov 21, 2020 | 08:43 PM
sevenup85's Avatar
sevenup85
Hi Martin, thanks again for your reply.
I assume you speak about the switch on the radiator that quicks in at a certain temperature right?
I will check the relay that might be locked on ON position
Old Nov 21, 2020 | 10:11 PM
GVK.'s Avatar
GVK.
I know you are new to the forum but you might want to post your theads in the correct section. ie Cosworth
Old Nov 22, 2020 | 09:28 AM
sevenup85's Avatar
sevenup85
Hi,
Sorry for the inconvenience, I thought the RS turbo for the cosworth, sorry about that.
I will move the thread if I can or else, will close this one and create a new one
Old Nov 23, 2020 | 01:41 PM
martysmartie
Correct, if the fan is on permanently, then it could be either a jammed relay or a faulty switch.
The easiest thing to do is disconnect the switch and see if they stop, if they do then the switch is faulty, otherwise it's the relay.
Martin
Old Nov 23, 2020 | 07:52 PM
sevenup85's Avatar
sevenup85
Problem solved, was in fact the fan switch, thanks
Mazda_man
Jun 11, 2019 09:14 AM
Chas
Oct 5, 2015 07:13 PM
Gems
Jun 26, 2010 08:59 AM
woodz77
Mar 21, 2009 08:38 PM
nutjob
Sep 19, 2006 08:46 PM
