Anybody knowledgable with the 2.5t engine?
Old Jun 26, 2020 | 12:15 PM
burnzy's Avatar
burnzy
burnzy
Default Anybody knowledgable with the 2.5t engine?
Got my Mondeo here, been faultless until last time I took it out, WOT at low rpm ie around 2k as it pulls it gets to about 3k and really stutters hard, then after about 4K will pull clean again.
its sporadic, it did it last time I had it out, but then cured itself but now it’s back again.
plugs are new before this issue arose and gapped, unplugged maf and no difference, visually inspected pipework and couldn’t find any splits, engine appears healthy other than this stutter/misfire, do the coil packs go on these?
Ive plugged Forscan into it and no codes, not even a misfire one?
anyone had or heard of similar issues?
thanks.
Old Jun 26, 2020 | 02:44 PM
ProjectBobcat's Avatar
ProjectBobcat
imrc? Is this the duratec v6 in them that was in the MK1/Mk2?
Old Jun 27, 2020 | 08:26 AM
burnzy's Avatar
burnzy
burnzy
Thanks mate but no, the is the mk2 focus 225 engine basically in a Mondeo 👍
I had a google and it may be the boost solenoid.
Old Jun 27, 2020 | 12:04 PM
I thnk them solenoids are common. You need to buy yourself a Forscan. Its a diagnosic tester just for fords. I bought mine off ebay for about 8 quid then you go on the Forscan website and download the software.
Its such a simple system to operate. You could log the turbo boost and do a roadtest and watch it on the laptop.
the forscan has helped me out with my diesel donkey mondeo.
Old Jun 27, 2020 | 06:34 PM
GVK.'s Avatar
GVK.
Don't think the boost solenoid gives a code.
Old Jun 28, 2020 | 10:20 PM
burnzy's Avatar
burnzy
burnzy
Thanks guys
glenn I must of bored you with my post as I say I’ve plugged forscan into it and no codes 🤣🤣 but yes I’ll look at logging my boost, iirc I couldn’t find a requested boost table only the MAP reading, also I was unsure if I’ve got a misfire if that would interrupt the boost as well making it not a definitive test.
GVK yea that’s what I was getting off google, and the symptoms are pretty much identical to the solenoid going as well.
Old Jul 1, 2020 | 04:26 AM
Thick as foook me.... i can't read for shit ha ha. Is it all the time or just every now and then??
I had a ST170 that at certain revs was stuttering. That turned out to be the filter on the fuel pump in the tank blocked.
Old Jul 2, 2020 | 10:14 PM
jc2000e's Avatar
jc2000e
Boost solenoid tends to only boost to 1/4 on gauge, does Mondeo have gauge? Kinda hit or miss when give it some
Old Jul 2, 2020 | 10:21 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I got my st225 with a miss fire at low rpm as it came on boost. I put new plugs in it and a boost solenoid and it fixed it
Old Jul 8, 2020 | 11:48 AM
costina's Avatar
costina
Live long and prosper!!
Yeah similar problems for me on a smax 2.5 but not plugs so will change the boost solenoid when i can be arsed
Old Jul 8, 2020 | 12:00 PM
ajamesc's Avatar
ajamesc
I’ve a mate who has worked for Volvo for 25 years he said there very very good engines and said the boost solenoids are a service item with Volvo. Didn’t cost much off Matt Lewis and easy to change at work on the ramp
Old Jul 8, 2020 | 12:08 PM
burnzy's Avatar
burnzy
burnzy
Thanks guys, I bought a new solenoid but sold the car before fitting it 🤣 the bloke haggled like fuck so the extra Ł50 he wanted knocked off after we already agreed a price i’ll re coupe most of it by returning the solenoid 🤣
Old Jul 8, 2020 | 05:56 PM
costina's Avatar
costina
Yeah its just getting time can't be bothered at lunch to get it on the ramp either eating or havin a nap....
Got the solenoid from matt just got to remember where i put it.🤔🙄
Old Jul 12, 2020 | 05:32 PM
costina's Avatar
costina
So i changed mine yesterday wheel off etc.
But why put the bloody thing there?
So all good now 👍
Old Jul 12, 2020 | 09:54 PM
burnzy's Avatar
burnzy
burnzy
How do you find the smax with the 2.5 engine? I wanted my ex to get one but she was having none of it 🤦🏻‍♂️
Old Jul 12, 2020 | 10:11 PM
ajamesc's Avatar
ajamesc
if it’s the same engine as the focus and same set up but a heavier body they must be incredibly bad on fuel lol
Old Jul 12, 2020 | 10:26 PM
costina's Avatar
costina
Yes and no on a run 70mph can see over 34 mpg boot it then its like a cossie.
But hey it does more than my old petrol 2.3 galaxy with the added fun factor.
What else can do 8 secs to 60 with a boot full of crap. I buy what i wanna drive regardless of economy.
I could do what other's do hsve a new car on pcp so i can look the part put a tenner in the tank and put budget tyres on it cos thats all they can afford.
Old Jul 13, 2020 | 06:54 AM
burnzy's Avatar
burnzy
burnzy
There is the zafira vxr that contends with the smax 2.5, it’s a shame the smax didn’t come with a kind of sport bodykit, as that’s what sets the zafira apart.
the Mondeo 2.5 would do 39mpg at a push so wasn’t that bad on fuel, there is some differences between the Mondeo and focus engine, I don’t know why the focus gets such low mpg though.
Old Jul 13, 2020 | 11:53 AM
costina's Avatar
costina
Gear ratios are different hence the focus is quicker of the line.
Book top end on a smax is 146 mph which is silly I'd rather have low end acceleration.
Old Jul 13, 2020 | 02:37 PM
ajamesc's Avatar
ajamesc
I’ve never seen over 26 on my focus lol. I even thought it must have something wrong with it but emissions are spot on. Looking at the forums 22-28 are normal
Old Jul 13, 2020 | 09:48 PM
costina's Avatar
costina
You have to press and hold the ok button when its on fuel consumption as it resets it. You will see the bars on the top of display.
Brickhouse
13
Aug 23, 2017 09:42 PM
scott_j166
Jul 4, 2013 08:42 PM
scottbrown
Mar 8, 2008 09:52 AM
saph in dorset
Jul 5, 2007 10:45 AM
