ST170 IMRC "different" problem
Old Apr 15, 2020 | 03:08 PM
GavsST170's Avatar
GavsST170
Default ST170 IMRC "different" problem
Hi. Yes, more IMRC issues! I have an issue that is slightly different from most.
After getting fault codes, I dismantled my system:
  • Mechanically, the flaps work fine.
  • I dismantled the IMRC servo unit, checked it, cleaned it, and re-assembled it.
  • I cleaned and lubricated the control cable
  • Re-assembled the whole system.
Now, when I start the engine the cable pulls the flaps open, and switching off releases them. However, with the engine running, the flaps do not release at 5000rpm, but only when it reaches just over 7000rpm, which is probably when the rev limiter activates. So in summary, the complete system all works fine except the IMRC doesn't respond to the rpm. I didn't replace the transistor, but would this be responsible for this issue? Does anyone know how the IMRC gets the rpm change signal and can I check this on 1 of the wires on the IMRC plug, or elsewhere?
Thanks for your interest.
jaimiemc
Mar 23, 2015 12:26 PM
Gmiester
Ford Focus ST
13
Nov 24, 2013 08:29 PM
B3nn3tt90
Aug 19, 2013 09:30 AM
FOCUSTARD PIE
Ford Focus RS
Aug 4, 2010 10:03 AM
j_cros1
Ford Focus ST
Oct 16, 2009 08:28 AM
