Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Aftermarket ECU/Tuning options for CVH 1.6 & 1.9L?
Old Jan 2, 2020 | 08:34 PM
Tempo111's Avatar
Tempo111
Default Aftermarket ECU/Tuning options for CVH 1.6 & 1.9L?
Hello.
I have a 1.9L CVH motor that came out of a 1990 US Escort GT. The motor was built with custom intake, porting/polish, cam, adjustable cam gear, rollers, forged internals, turbo, blah blah blah.
I believe it is similar to the Euro 1.6L CVH.
Was wondering what everyone is using to run these engines when they build them beyond the capabilities of the stock ECU/Carb???
BACKGROUND: The motor was built almost 2 years ago and I spent several months trying to get the darn thing to run using a Mega Squirt ECU. I have fuel, ignition, compression, etc. Have gone thru two Mega Squirt units, several coils, several distributors, wires, plugs, etc. I was unable to get the engine to fire and gave up. I would like to try once more to get this motor running before I move on. I have ran several other distributor equipped Ford engines over the years on a Mega Squirt, every single one was a pain to get running and trouble shoot. If I can not get this motor running, I was going to get a newer non-distributor version of the 1.9L, transfer some parts over and run it on a different ECU and just live with less HP.
Any help would be greatly appreciated!
Thanks
Adam
Old Jan 27, 2020 | 09:58 AM
my0wn3ds's Avatar
my0wn3ds
What Megasquirt setup you try? TFI or crank trigger?
Old Jan 30, 2020 | 10:33 AM
XR2's Avatar
XR2
uuuuh megasquirt. The cheapest option for an aftermarket ECU. But when you've done everything correct, the engine still will be running. CVHs are as easy/hard as other engines to run on an aftermarket ECU.
1. When cranking do you have a correct and stable CPS reading?
2. assumed 1 is working: When trying to start, do you have an ignition spark? If yes: ignition timing set???
3. assumed 1 AND 2 are ok: Are your injectors working?
4. assumed 1/2/3 are ok: Plugs wet or dry?
adampotten
Oct 1, 2012 08:08 PM
enduro.nick
Feb 9, 2012 07:06 PM
Martin//TwistedTuning
Aug 3, 2010 09:11 PM
slim20012
Sep 3, 2006 10:25 AM
