S2 management
Old Nov 25, 2019 | 07:30 PM
Joshmk1's Avatar
Joshmk1
Default S2 management
bought a s2 that’s on cosworth management it’s still running the dizzy what’s needed to change to coil pack?
Also I have a ofam boost moneys Ecu am I right in saying Il have to change the loom to run this on the s2?
Old Nov 25, 2019 | 08:26 PM
studabear's Avatar
studabear
Coil pack, wasted spark driver in the ecu, probably also need a wasted spark sub loom and a additional ignition amplifier. Then a mod to the rev counter. Or you may be able to use a P8 ecu but I can't remember tbh. Motorsport developments would be your people to speak to.
Ofam would need engine loom from a frst or a efi escort with some pin changes iirc. A lot of people want them OFAM ecu's you should have no trouble selling it if you choose to.
Old Nov 25, 2019 | 08:39 PM
Joshmk1's Avatar
Joshmk1
Thanks buddy! I’m torn I dunno weather to go p8 or go ofam.
What do people think? Pro’s and cons?
Old Nov 26, 2019 | 01:24 PM
Rogeyboy's Avatar
Rogeyboy
Go OFAM if you wanna map it yourself...
Failing that speak to Jano OddKidd and he will fit wasted spark and map the cossie management.
Old Nov 26, 2019 | 06:35 PM
studabear's Avatar
studabear
I had nothing but trouble with cossie management. Personally I would go for a more modern system. A modern system will have all the extra buts out the box like coil pack, closed look fueling and boost control etc etc.
kyam786
Dec 30, 2017 04:03 PM
ricky
Jul 31, 2015 10:30 PM
Stu @ M Developments
Oct 16, 2006 03:06 PM
rsrob
May 8, 2005 04:20 PM
TILLIO
Nov 2, 2004 08:56 PM
