Heater problem.
Old Oct 7, 2019 | 05:11 PM
focus on ford's Avatar
focus on ford
Angry Heater problem.
Can anybody give me inform on a problem I have with my car hearter. It work hot and cold But the last couple of days,. ONLY works on No.4.can anybody help (inform) Paul.
Old Oct 7, 2019 | 06:14 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
Hi a new switch is often needed if you wiggle or push the switch and flick between 1.2.3. it may work for a moment, and identify your faulty part,
Old Oct 7, 2019 | 06:17 PM
focus on ford
Thanks I will try that tomorrow. I have gone up and down, but just the normal way. I will try as you have said tomorrow thanks Paul.
Old Oct 7, 2019 | 06:19 PM
Giorgos92's Avatar
Giorgos92
Hi Paul, since your blower only works on the highest speed setting, I'd replace the blower motor resistor. I believe that's the first thing to check in a situation like that and its pretty cheap to replace.
Old Oct 7, 2019 | 06:30 PM
focus on ford
Thanks where will I find that, is it in the fuse box inside the car? thanks Paul.
Old Oct 7, 2019 | 06:43 PM
GVK.'s Avatar
GVK.
Be on the heater box itself
Old Oct 7, 2019 | 06:44 PM
focus on ford
Great thanks to you ALL, for your help with this problem Paul.
Old Oct 11, 2019 | 10:14 AM
Giorgos92's Avatar
Giorgos92
Just as GVK says, the resistor is on the heater box, it has some wires going in to it and is held in by a screw, if you remove the wiring clip and the screw the resistor should come right out. You put the new one in, screw it on, clip on the wiring and test for proper operation of the blower motor. Good luck with it and let us know how you get on
Old Oct 14, 2019 | 03:30 PM
What make of car is it?? I know of some cars where the heater resistor has been locked by a passenger and stopped them from working.
Old Oct 14, 2019 | 04:57 PM
focus on ford
Focus 02, some of the members have said what it could be. Just have not getting around to get the part just now. But it will not wait, it is going to have to be done ASAP Paul.
Old Oct 14, 2019 | 07:14 PM
9 times out of 10 it will be the resistor.
Old Oct 15, 2019 | 07:22 AM
focus on ford
Thanks, I just need to get one then fit it. Just the sellers on ebay don't have good rating, so will have to visit the scrap yard I think thanks for you help Paul.
Old Nov 19, 2019 | 04:23 PM
focus on ford
Smile
Just like to say BIG thank you, to the members of the group. For the help they give with this problem. The instrucations, that you all give was spot on. helped me solve the problem, with my heating Thanks Paul.
bikeruk111
Ford Focus (All Models)
11
Jun 17, 2013 08:45 AM
Kallydog
Fiesta RS1800/RS Turbo
Nov 30, 2010 12:25 PM
corby turbo
Apr 8, 2008 06:33 AM
MATCOS
Feb 25, 2006 03:11 PM
MATCOS
Feb 1, 2006 02:27 PM
