Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
ST225 no boost
Old Aug 21, 2019 | 10:44 AM
David Manca's Avatar
David Manca
Default ST225 no boost
Hey, i have some issues with my ST225.
It all started with slowly down boosting (from 4/4 to 0/4 of boost.
It gave full boost, after 50 miles just only 3/4, then 2/4 etc to 0 boost.
The needle of boost gauge doesn't even move a bit, only when i do full throtle and then take off throtle pedal, but Its really a bit (like 1/6 of boost)
Im mad of it, becouse it have power like some 1.2htp 40kw
I changed the boost solenoid, MAF, MAP and even with the new turbocharger, it's still the same.
The engine RPM goes max around 5-6k, and sometimes doesn't go even on 4k.
When i take off the turbocharger pipe to intercooler, it seems like turbo works well (feel that air in my face really good)
Only what doesn't work on that turbo Is Wastegate, but it doesn't work, becouse that little pipes from turbocharger to Solenoid valve doesn't have any air in them, only a bit at full throtle, but i can't tell why...
Do you guys have some advice?
Thanks for your time. Hope someone will know.
Old Aug 28, 2019 | 12:37 AM
Francismcginn27's Avatar
Francismcginn27
F420
Default check vacume pipe to waste get
Check your vac pipes in round your turbo and boost control solenoid they can crack if they are still the original ones that were on from factory
stevedb
Oct 20, 2008 02:57 PM
baba
12
Apr 13, 2008 09:06 AM
Rob84
Sep 18, 2007 04:07 PM
peteh
Mar 11, 2006 10:37 PM
AlexF
Apr 3, 2005 08:04 PM
