General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Was supposed to be having the timing belt done today on my puma 1.7 engine while its out.
A mate of mine offered to do it but while doing it I seen him damage the end of the camshaft, basically because from what I can tell he had the locking bar in place while trying to loosen off the cam pulleys, this caused the end off the shaft to chip off where the locking tool was. he immediately said 'can't do it now' and left. So I'm left with a damaged cam and no cam belt as he took the old one off.
here's the pics what do you think?
The bit that's broken serves no purpose other than for locking the cam in place when setting the cam position.
It's NOT to be used when loosening / tightening the Crankshaft bolt.
Originally Posted by GVK.
As above - There's a special tool that locks into the pullies to slacken the pulley bolts.
Seen this happen mAny times working in garages over the years, happened once to myself stupidly but we all live and learn and I certainly didn't make that mistake again! As long as the broken piece is retrieved then it causes no harm at all as that part is only for the locking of the cams. Nice of him to fook off and leave you in the shit though! Easily remedied
I've done the same thing with a Focus . I couldn't just fuck off tho ! By the looks of it you can still get the timing bar I the end of the Cam so you should be still good . I'd use a pair grips to hold the cam when you nip the pulley bolt up
ok thanks for replies, made me feel better anyway, ill see if i can get a mobile mechanic out this week to do it. wish id done that to start with.
oh, and i sent my 'mate' a final text message. he replied with with some shit about how he didnt want anything for doing it so what am i complaining about.
cunt.
easy if you know what your doing, ill do basic things to the car myself but things like this are best left to a pro Imo. I don't fully understand it really, I've only got to get it slightly wrong and I've caused myself a load of grief. If a so called mechanic has fucked it up already what chance do i have at getting it right!
Glenn, very detailed information which for someone with good mechanical skills is probably straight forward but for st220kyle may be, as he has said pretty difficult ,so he will be happier to get it sorted out by a proper qualified mechanic.
