cosworth battery
Old Mar 24, 2019 | 11:46 AM
killa_paul's Avatar
killa_paul
Default cosworth battery
So im looking for a replacement decent battery,
the battery i have has lasted about 4 years but because of the alarm and little use it is always going flat.
i have now got to the point where the battery is completly falt after two days and wont fully charge or hold charge this is with an optimate connected .
obviousley i have a clifford ca1 1 alarm and tracker fitted to the car but it seems the current drawn from the alarm is more the the optimate can now keep up with as the battery is so low.
ive tried new acid and water in the battery but its had it.
what are the best heavey duty batteries for the replacement .
its a 2wd sapphire any idea what the bigest battery would fit and how many amp hrs it is,
what batteries do you recomend .. the car doesent get used much atm but will be out in the summer
thanks in advanced
Old Mar 24, 2019 | 02:56 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Do you want original style flat post or round?
Old Mar 24, 2019 | 03:00 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
If original flat post style options are limited.
numax from eBay etc or lion from euro car parts.
I got the lion from euro car parts about Ł41 with a 50% discount code. Working well with no issues but I also use an isolator when left for extended periods.
Old Mar 24, 2019 | 05:26 PM
bigdel's Avatar
bigdel
I have Lion on mine. Not quite as much space for the accessory take off plate that goes over the +ve terminal so had to shave a bit off the terminal to make it fit. Other than that, all good.
I've stripped off all the Lion branding too with the intention of replacing them with a set of Ford graphics, but haven't got round to that yet
Old Mar 24, 2019 | 06:59 PM
killa_paul's Avatar
killa_paul
not fussed on round or flat posts
Old Mar 25, 2019 | 09:47 AM
martysmartie's Avatar
martysmartie
It's tight with the standard, so don't think you could go much larger.
Even with what you mention, I don't believe the draw would be that great, around half an amp (i.e. 500 Ma) I should imagine, which the charger should have no issue with.
@bigdel yes I have noticed this, with the positive and filed the terminal slightly to get the plate to sit.
I have a Tayna.
Martin
Old Mar 25, 2019 | 10:21 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
Just had a quick check and the lion is Ł41.50 from ecp with code sale55.
if your killa - ing them regularly go with the cheap option mate.
Old Mar 25, 2019 | 11:18 AM
bigdel's Avatar
bigdel
Whatever you decide to do, once the new battery is fitted, get yourself a CTEK battery conditioner and leave it connected all the time the car is standing idle (especially for long periods), a constant low drain on the battery will kill it very quickly unless you keep the charge up by some external means
I used to kill a battery every winter whilst the car was laid up. Bought a CTEK about 10 years ago and the same battery lasted until last year when I put the car into storage over winter and forgot to give the storage place my CTEK. It came out of storage and the battery was goosed. By that time, Ford had stopped making the flat terminal batteries so had to get a replacement elsewhere
Old Mar 28, 2019 | 09:44 AM
cossynut2's Avatar
cossynut2
10 Year Member
I have a Tayna.
Martin
I have the flat post Tanya on my 2wd Saff. Took the japanese Rising Sun flag sticker off and replaced it with Ford Motorcraft sticker so it looks like original Ford fitment.
Old Mar 31, 2019 | 12:35 PM
martysmartie
Remember you mentioned that in another thread, good idea
Incidentally after 16 years I've just replaced a Motorcraft battery, so think I got my money's worth
Martin
Old Mar 31, 2019 | 05:28 PM
cossynut2's Avatar
cossynut2
10 Year Member
You certainly had good service from your Motorcraft battery, most don't last that long.
Old Mar 31, 2019 | 06:19 PM
qed296's Avatar
qed296
Did mine aswell, flat post from andrew pages....Ł40 i think....decals from dmb
Old Mar 31, 2019 | 06:23 PM
martysmartie
It sure did, from my first/daily car.
You handing off to a junction, just the one cable?
Martin
Old Mar 31, 2019 | 07:53 PM
qed296's Avatar
qed296
Yeah, made a massive improvement to starting, window operation etc etc....i dis replace the cable with new
Old Apr 1, 2019 | 03:37 PM
cossynut2's Avatar
cossynut2
10 Year Member
What is the round metal dish for next to your battery?
Old Apr 1, 2019 | 04:11 PM
qed296's Avatar
qed296
Extra horn.
Old Apr 1, 2019 | 05:45 PM
tosh's Avatar
tosh
Totally off topic but did all sapph’s have a rubber seal on the bottom of the plastic schuttle panel? Not noticed that before.
Old Apr 2, 2019 | 08:12 AM
cossynut2's Avatar
cossynut2
10 Year Member
Yes, it is on all Saff's. Weather seal for the back of the bonnet.
Old Apr 2, 2019 | 11:59 AM
tosh's Avatar
tosh
Thanks time I start shopping then but have never seen them.
Apologies to the op for interrupting his thread but I had to ask.
Old Apr 4, 2019 | 03:09 PM
killa_paul's Avatar
killa_paul
as stated previous i have an optimate connected on the battery but its still dead . although it was a halfords battery
Old Apr 4, 2019 | 06:17 PM
cossynut2's Avatar
cossynut2
10 Year Member
I have fitted a solar powered trickle charger that has quite a big solar panel on the roof of my garage and the wire comes inside to connect up and I find providing we get some sunny days it keeps the battery topped up ok. Before I fitted it up it was a pain in the ass as with the drain of the immobiliser 9 times out of 10 the battery was flat when I wanted to take it out and it had to be jump started.
Old Apr 7, 2019 | 08:54 PM
Jules44's Avatar
Jules44
10 Year Member
where is the rest of the wires?
Old Apr 7, 2019 | 08:59 PM
qed296's Avatar
qed296
8 posts up
Old Apr 22, 2019 | 07:24 AM
Jules44's Avatar
Jules44
10 Year Member
So what did you use and where from?
Old Apr 22, 2019 | 07:31 AM
qed296's Avatar
qed296
12v/24v terminal block from ebay
wilcox
Apr 5, 2019 08:22 PM
TurboBoost
Jan 25, 2016 07:21 PM
bill
Oct 14, 2004 04:26 PM
