hunting at idle
Old Feb 22, 2019 | 03:37 PM
RUBY123's Avatar
RUBY123
Default hunting at idle
wondering if anyone has any ideas car will idle at around 600rpm and will idle at 1500 rpm anywhere inbetween it hunts up and down. I've pressuresised the system there are no vacume leaks changed fuel pump fuel filter and fuel regulator and no change also when it's hunting it's going lean and putting fuel in those areas doesn't help
Old Feb 22, 2019 | 03:41 PM
RUBY123's Avatar
RUBY123
also idle valve is unplugged
Old Feb 22, 2019 | 04:46 PM
cossie2's Avatar
cossie2
...is it same while cold or hot engine...?if so you might have tps set up issue..
Old Feb 23, 2019 | 07:35 PM
RUBY123's Avatar
RUBY123
same hot or cold it on aftermarket so can calibrate the tps to anything so thats not the problem. thanks for the suggestion
Old Feb 23, 2019 | 09:43 PM
martysmartie's Avatar
martysmartie
It's not TPS due to the fact you state it's the same with the ISCV disconnected, therefore you have an air leak, check gaskets (i.e. plenum).
You can use WD40 to trace, if need be.
Martin
Old Feb 24, 2019 | 06:57 AM
Mark Shead's Avatar
Mark Shead
The map needs tweaking.
Mark
Old Feb 24, 2019 | 07:43 AM
cossie2's Avatar
cossie2
let us know how it went at the end..
Old Feb 24, 2019 | 10:08 AM
RUBY123's Avatar
RUBY123
it's not a air leak as I have pressurised the intake system and there is no leaks. the map areas were it's hunting I've added fuel removed fuel added ignition removed ignition nothing helps could crank sensor or cam sensor gap cause this sort of issue
Old Feb 24, 2019 | 01:02 PM
turbotrev's Avatar
turbotrev
Mark
Thats what I was thinking, esp as you said the ISCV is disconnected
Cheers Paul
Old Feb 24, 2019 | 01:30 PM
RUBY123's Avatar
RUBY123
it's only disconnected to set base idle but as it's hunting I can't set base idle it's a visious circle lok
Old Feb 25, 2019 | 02:38 PM
RUBY123's Avatar
RUBY123
think it's the cam sensor gap you can see the voltage dancing about on the ecu software
Old Feb 26, 2019 | 09:41 PM
col93saphcos's Avatar
col93saphcos
Could be the coolant sensor in the cylinder head
Old Mar 5, 2019 | 09:46 AM
Loomer's Avatar
Loomer
Worth a check of the voltage at pin 20 of the ECU, ensure its very close to battery voltage which should be in the 14v range ideally.
Old Mar 6, 2019 | 04:11 PM
RUBY123's Avatar
RUBY123
Thumbs up
had a play with it today closed the gap on the cam sensor and played with a few settings and it now idles as it should. thanks for all the help and suggestions
Old Mar 9, 2019 | 08:33 AM
cossynut2's Avatar
cossynut2
10 Year Member
Nice when it all gets sorted out fairly easily.
Weeksy
Oct 23, 2011 07:14 PM
Lee Ivatt
Ford Escort RS Cosworth
16
Apr 24, 2008 04:36 AM
richard_xr2i1800
Escort MK 5 / MK 6
May 9, 2007 12:26 PM
NIMRODS_RST
Dec 12, 2005 06:59 PM
NIMRODS_RST
13
Dec 11, 2005 09:57 PM
