Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
RS2000 Hunting Idle Problem
Old Mar 3, 2007 | 06:07 PM
richard_xr2i1800's Avatar
richard_xr2i1800
Default RS2000 Hunting Idle Problem
Hello as above the cars idling bad, it hunts up and down, i have cleaned the idle valve but made no difference
Anyone got any ideas
Rich
Old Mar 7, 2007 | 07:21 PM
EscortMatt's Avatar
EscortMatt
Maybe throttle position sensor...?
Old May 7, 2007 | 09:31 AM
craigos's Avatar
craigos
clean the idea speed control valve out with card cleaner mate worked for me
Old May 7, 2007 | 09:40 AM
chink's Avatar
chink
mine was doing the same turned out to be the rubber rings on the injectors
Old May 8, 2007 | 03:25 PM
john16v's Avatar
john16v
Mine is doing the same and sometime dies. Sprayed the whole inlet to check for leaks, nothing, cleaned the ISCV nothing.....now thinking that the ISCV is completely buggered
Old May 9, 2007 | 12:26 PM
danrs2k's Avatar
danrs2k
My rs2k had this problem all i did to over come it was take the idle control valve off strip it down n get rid of all the carbon build up i used brake cleaner blasted it though it valve then hung it on the washing line till dry, put it back together then no probs since.
*touch wood*
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
routemaster
Sep 7, 2015 05:27 PM
